- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
Posted on 10-24-2013 08:39 AM
following script being deployed via casper remote or policy
osascript -e 'tell application "System Events" to delete login items';
and I get the following error: Runs perfect when run through local terminal
Mounting Casper Distribution to /Volumes/casper...
Running script Clear Login Items.sh...
Script exit code: 1
Script result: 43:54: syntax error: A plural class name can’t go after this identifier. (-2740)
Any help would be appreciated.
Solved! Go to Solution.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Posted on 10-24-2013 11:00 AM
This may be overkill, but you could try this-
loggedInUser=$( ls -l /dev/console | awk '{print $3}' )
loggedInPID=$( ps -axj | awk "/^$loggedInUser/ && /Dock.app/ {print $2;exit}" )
/bin/launchctl bsexec "${loggedInPID}" sudo -iu "${loggedInUser}" "open /Users/Shared/DeleteLoginItems.app"
Stolen, err, borrowed code from others here that have done this before me. I use similar syntax in another script that has to call terminal-notifier.app as the logged in user.
If the above works, I'd go back and try using your original osascript code above instead of the call to an app to see if that works as well. Only thing is, you need to backslash escape any quotes in the osascript line (singles or doubles) or it won't work.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Posted on 10-24-2013 08:56 AM
Remember Casper is going to be running your scripts as the root user, not the locally logged in user... you may need to create a variable for the currently logged in user and then use a "sudo -c" to get it done...
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Posted on 10-24-2013 09:04 AM
I have tried
sudo -u "$loggedInUser" /usr/bin/osascript -e 'tell application "System Events" to delete login items'
Same error.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Posted on 10-24-2013 09:16 AM
Hey Everyone,
I have seen this before when using Applescripts to migrate end user's exchange server settings in Outlook. I actually had to save my Applescript as an application, and then run the open command to have the user open it. I think this is due to some of the newer sandbox environments OS X has added since 10.7. So, I would save the Applescript as an app and toss it in my scripts folder in my CasperShare. Then run something like this:
currentUser=$(ls -l /dev/console | awk '{ print $3 }')
sudo -u ${currentUser} open /Volumes/CasperShare/Scripts/myapplescript.app
The code would execute as that end user, and it would run like an app instead of an actual Applescript. This is how I got around the whole run as root and sandboxed environments of OS X.
Hope this helps you,
Tom
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Posted on 10-24-2013 09:45 AM
fails out with the following error
Script exit code: 0
Script result: LSOpenURLsWithRole() failed with error -10810 for the file /Users/Shared/DeleteLoginItems.app.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Posted on 10-24-2013 10:46 AM
Hi msardes,
This is what I did and I just double checked this in my test environment:
Open Applescript Editor and create this script:
delete login items
end tell
Then export that script to an application, via the export menu. I have a local test account on my Macbook Pro named, "Tom Waits." The shortname is 'tomwaits,' and I fast user switched to that user, opened up a terminal session, switched the terminal session to the root user, and opened the app from my home folder, as root, but as the currently logged in user:
bash-3.2# whoami
root
bash-3.2# sudo -u tomwaits open /Users/tlarkin/Desktop/deleteLoginItems.app
bash-3.2#
In return the start up items I set for the user account Tom Waits, were in fact deleted. I had added Safari and VMware Fusion assistant as two start up items. If this is further not working for you I will toss it in my virtual JSS when I have a few minutes later today to fully test. As of right now I have only tested it locally. I did get the expected results though.
I hope this fixes it,
Thanks,
Tom
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Posted on 10-24-2013 10:51 AM
it all works fine when I run in terminal locally however its when i run a script invoking the app that I get the error.
Script
sudo -u ${currentUser} open /Users/Shared/DeleteLoginItems.app
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Posted on 10-24-2013 11:10 AM
Could you post both your apple script and the bash script you are using to run it?
Thanks,
Tom
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Posted on 10-24-2013 11:14 AM
as in:
sudo -u "$loggedInUser" /usr/bin/osascript -e ' ell application "System Events" to delete login items'
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
as in:
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Posted on 10-24-2013 11:19 AM
AppleScript
delete login items
end tell
Shell Script:
alternatively I would just like this to work with shell script as in:
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Posted on 10-24-2013 11:30 AM
Almost right/ Make sure to put the backslashes before the quote marks for one, not after them. Also, quote the entire command you're instructing the script to run as the user. So like this
sudo -iu "$loggedInUser" "/usr/bin/osascript -e 'tell application "System Events" to delete login items'"
Lastly, note I'm using sudo -iu, not sudo -u
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Posted on 10-24-2013 11:43 AM
script changed to
following error:
Running script Delete Login Items.sh...
Script exit code: 1
Script result: 0:1: syntax error: A unknown token can’t go here. (-2740)
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Posted on 10-24-2013 11:45 AM
btw the apple scrips one worked however If I can just do this with a shellscript that would rock.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Posted on 10-24-2013 12:17 PM
ok doing this:
Delete Items apple script app in /Users/Shared
this shell script to invoke at login
sleep 1
works great, thanks guys and girls.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Posted on 08-05-2014 01:05 AM
mm2270 you legend, that works a treat.
