Script running su "$currentuser"
  • February 6, 2023
  • 111 views
DBrowning
I have a script that is running a lot of commands starting with
su "$currentuser" -c
When the policy is run locally or via Self Service the script runs as expected.  When I let it run via check-in, all the lines that start with the above command do not run.  Any ideas?
Best answer by mm2270
There is a difference between the natural Jamf check-in that gets started via the LaunchDaemon, versus a manual check-in or policy execution (Self Service, doing sudo jamf policy, etc.) The former gets executed entirely in a root context, whereas the latter ones typically run as the user with elevated rights.
All this is to say, I've seen this type of problem before. What typically has worked for me is to use the launchctl asuser syntax you can find here:
https://scriptingosx.com/2020/08/running-a-command-as-another-user/
  • February 6, 2023
Are you sure that there is always a currentuser during checkin?
  • February 6, 2023
piotrr
  • February 8, 2023
If you echo currentuser you might notice that it's root.
