Posted on 04-05-2023 03:21 AM
Hi all,
We have this script in place to merge or override favourite servers on our clients;
#!/Library/Frameworks/Python.framework/Versions/2.7/bin/python
# change the above path to your own python if you don't have Munki installed
Merges add_servers into current favorites and removes remove_servers.
Run as root to update all users or as normal user to update just that user.
import os
import getpass
import subprocess
import uuid
import Foundation
favorites_path = "/Users/{user}/Library/Application Support/com.apple.sharedfilelist/com.apple.LSSharedFileList.FavoriteServers.sfl2"
# add these servers if they don't exist already
# use a tuple: ("<name>", "<path>") to set a name for the favorite.
# otherwise just use a string and the path will be used as the name
add_servers = (("My Name", "smb://server.example.com/share"), "vnc://server.example.com")
# remove these servers if they exist. Use a wildcard (*) at the end to remove all shares
# does not support ("<name>", "<path>") syntax
remove_servers = ("smb://old.example.com/*", "vnc://old.example.com")
def get_users():
"Get users with a home directory in /Users"
# get users from dscl
dscl_users = subprocess.check_output(["/usr/bin/dscl", ".", "-list", "/Users"]).splitlines()
# get home directories
homedir_users = os.listdir("/Users")
# return users that are in both lists
users = set(dscl_users).intersection(set(homedir_users))
return [u.strip() for u in users if u.strip() != ""]
def set_favorites(user, add_servers, remove_servers):
"Set the Server Favorites for the given user"
# read existing favorites file
data = Foundation.NSKeyedUnarchiver.unarchiveObjectWithFile_(favorites_path.format(user=user))
# reformat add_servers to [(name, path), ...]
new_add_servers = []
for s in add_servers:
if len(s) == 2:
new_add_servers.append(s)
else:
new_add_servers.append((s, s))
add_servers = new_add_servers
existing_servers = []
# read existing items safely
if data is not None:
data_items = data.get("items", [])
# read existing servers
for item in data_items:
name = item["Name"]
url, _, _ = Foundation.NSURL.initByResolvingBookmarkData_options_relativeToURL_bookmarkDataIsStale_error_(Foundation.NSURL.alloc(), item["Bookmark"], Foundation.NSURLBookmarkResolutionWithoutUI, None, None, None)
existing_servers.append((name, url))
# get unique ordered list of all servers
all_servers = []
# add existing_servers to list, updating name if necessary
for s in existing_servers:
try:
idx = [a[1] for a in add_servers].index(s[1])
all_servers.append((add_servers[idx][0], s[1]))
except ValueError:
all_servers.append(s)
# add add_servers if not present already
if s[1] not in [e[1] for e in existing_servers]:
# remove old servers: exact match
# matches "smb://old.domain" exactly
all_servers = [s for s in all_servers if s[1] not in remove_servers]
# remove old servers: shares
# matches "smb://old.domain/*"
all_servers = [s for s in all_servers if len(
[True for r in remove_servers if r.endswith("*") and str(s[1]).startswith(r[:-1])]
) < 1]
# generate necessary structures
items = []
for name, path in all_servers:
item = {}
item["Name"] = name
url = Foundation.NSURL.URLWithString_(str(path))
bookmark, _ = url.bookmarkDataWithOptions_includingResourceValuesForKeys_relativeToURL_error_(0, None, None, None)
item["Bookmark"] = bookmark
# generate a new UUID for each server
item["uuid"] = str(uuid.uuid1()).upper()
item["visibility"] = 0
item["CustomItemProperties"] = Foundation.NSDictionary.new()
items.append(Foundation.NSDictionary.dictionaryWithDictionary_(item))
data = Foundation.NSDictionary.dictionaryWithDictionary_({
"items": Foundation.NSArray.arrayWithArray_(items),
"properties": Foundation.NSDictionary.dictionaryWithDictionary_({"com.apple.LSSharedFileList.ForceTemplateIcons": False})
# write sfl2 file
Foundation.NSKeyedArchiver.archiveRootObject_toFile_(data, favorites_path.format(user=user))
# loop through users and set favorites
if __name__ == "__main__":
# if running as root, run for all users. Otherwise run for current user
user = getpass.getuser()
if user == "root":
users = get_users()
else:
users = [user]
for user in users:
try:
# fix owner if ran as root
if user == "root":
os.system(("chown {user} " + favorites_path).format(user=user))
print("Server Favorites set for " + user)
except Exception as e:
# if there's an error, log it an continue on
print("Failed setting Server Favorites for {0}: {1}".format(user, str(e)))
# kill sharedfilelistd process to reload file. Finder should be closed when this happens
os.system("killall sharedfilelistd")
We're receiving following errors;
Script result: Traceback (most recent call last):
File "/Library/Application Support/JAMF/tmp/Favourite servers MERGE", line 14, in <module> import Foundation ImportError: No module named Foundation
Does anyone have an idea on how to fix it? Or an alternative way to merge & override favourite servers in the Finder?
Big thanks in advance,
Sander.
Posted on 04-05-2023 04:30 AM
MacOS retired python 2.7 early last year, I would start by updating this script to python 3 and adjusting your shebang accordingly.
Posted on 04-06-2023 10:03 AM
The file com.apple.LSSharedFileList.FavoriteServers.sfl2 is protected by TCC so the script will not work.
Unless I am mistaken there is no way to modify this file without disabling SIP.
