Posted on 05-03-2016 06:39 AM
I made this script because I needed to remove an intermediate certificate from machines. You'll just need to pass the SHA-1 hash as variable $4.
# ABOUT THIS PROGRAM
# NAME
# RemoveCertSHA1.sh -- Removes a certificate in the system keychain based on it's SHA-1 hash
# SYNOPSIS
# Add RemoveCertSHA1.sh to the scripts in a policy
# Pass the SHA-1 hash to the script as $4
# LICENSE
# Distributed under the MIT license
# HISTORY
# Version: 1.0
# - v.1.0 Luis Lugo, 2.5.2016
echo "Using $4 as the SHA-1 hash"
# Find all certificates in the System keychain and put them in an array by their SHA-1 hash
IFS=$'
sha1Array=( $(security find-certificate -a -Z '/Library/Keychains/System.keychain' | grep -e 'SHA-1 hash:' | cut -c 13-54) )
echo "Number of certificates found: ${#sha1Array[@]}"
# Loop through the array of certificate hashes and look for the one passed to the script
for (( i = 0 ; i<"${#sha1Array[@]}" ; i++ ))
do
# Is the current array member the one we're looking for?
if [[ "${sha1Array[i]}" == "$4" ]]
then
# This is the certificate we're looking for
echo "Certificate found!"
security delete-certificate -Z $4
# Did it delete successfully?
if [[ $? == 0 ]]
then
echo "SUCCESS: Certificate removed!"
jamf recon
echo "ERROR: Failed to remove certificate!"
exit $?
done
# The certificate was not found in the array
echo "INFO: Certificate NOT found!"
