Posted on β11-05-2018 01:24 PM
For those of us new to scripting, and trying to get passably good at it, I am wondering if there are any resources available through jamf to assist in this. For example, is there a generic script library I can pull from? If I wanted to issue terminal commands based on who is logging in, what is the easiest way to do this in a script?
Posted on β11-05-2018 05:07 PM
On JAMF Nation, under "More" on the Main Menu there is a category "Scripts".
Seth
Posted on β11-05-2018 05:15 PM
hello and welcome!
I'd start by searching on github, tons of other macadmins have published repos with their scripts.
most of us arent scripting based on "who's logging in", if we are we're using something like jamfconnect to facilitate login scripts
Posted on β11-06-2018 06:41 AM
Ask your jamf buddy about the Jamf Training. If you have a Cloud Based or Subscription Based Jamf Pro Contract you can get access to the Jamf Training Portal that has modules available for Scripts. If you have a perpetual based susbscription you cannot access this but may be able to get a free trial.
Posted on β11-06-2018 12:22 PM
Awesome that there are 119 scripts that have been uploaded to More > Scripts. How do I upload the one the I wrote so others can use it?
Posted on β11-06-2018 12:42 PM
@Morningside You can upload scripts through a product page. For example, if you had a script that was related to say, Adobe Flash Player, you would go to the 3rd Party Products Flash Player page, then click on Scripts and you will see a button to upload scripts there.
For more generic scripts not related to some specific software title you can always use "Mac OS X" or a more specific version, like "MacOS Sierra" In fact, if you look at the previous "Mac OS X" page, you'll see 48 scripts attached to that.
I'm not 100% certain, but I believe someone at Jamf reviews the script before it becomes available for others, just to be sure nothing malicious makes it up there.
Posted on β11-06-2018 01:32 PM
My suggestion is to also open up posts here in JAMF Nation. Often times members, myself included, will post questions for help on a certain topic, and then come back and post answers to those questions. When a script is the key, many/most members will post the script that works as the fix for them. For me, an example is HERE where I asked a question, made sure to put a decent subject and then throw my script in, plus marking the answer. While you're not directly uploading a script to the Scripts category, it is searchable by google. So if you just google search for "jamf script [subject]" I get a lot more hits than if I just browsed the Scripts category.
