Posted on 09-05-2023 12:45 AM
I hope you're doing well. I'm currently working on a project within our organization that requires students to input admin credentials when they first launch an application. To simplify this process and reduce the workload on our technology department, I'm exploring options to automate the initial credential input.
Specifically, I'm looking for a way to streamline the admin login process when students launch the application for the first time. I'd like to avoid manual input of credentials and make this more efficient for both students and our IT team.
Has anyone here encountered a similar requirement, and if so, how did you address it? Are there any tools, scripts, or best practices that can help automate this admin credential input during application launch?
Posted on 09-05-2023 06:15 AM
What is the application and what is it trying to do that is requiring Admin credentials during the first login? Most applications do not require Admin credentials to launch. However, some applications install helper applications and prompt for admin credentials since the helper applications are often installed in the /Library folder.
