Send mobile device command to mobile device smart group
jose_gutierrez
New Contributor II
Hello!
I need to send the update inventory command to my iPads to be able to check when they run out of battery.
Gladly i succeeded writing the test script to send it to one device, but i im looking for a way to send it to a whole group instead of doing it device per device.
This is the beautiful script.
deviceID="59"
# This works for single commands
data="<mobile_device_command><general><command>UpdateInventory</command></general><mobile_devices><mobile_device><id>59</id></mobile_device></mobile_devices></mobile_device_command>"
curl -fsku "${usr}:${pass}" -H "Content-Type: text/xml" "${jssdomain}/JSSResource/mobiledevicecommands/command" -d $data -X POST
Do you have any idea of how would it work for mobile devices smart groups?
Regards!
3 REPLIES 3
evan684
New Contributor II
I'll bump this since I actually have the same question.
SamF
Contributor
To send this to multiple devices, you would just add additional instances of the mobile device ID to the existing XML array. For example:
    <general>
    </general>
    <mobile_devices>
        <mobile_device>
            <id>59</id>
        </mobile_device>
        <mobile_device>
            <id>60</id>
        </mobile_device>
    </mobile_devices>
AdamBaali
New Contributor
@jose.gutierrez @evan684
Had the same problem and thought this might help you guys out
jamfProURL="https://jamf.jamfcloud.com"
jamfUser="jamf.admin"
jamfPass="jamf1234"
mobileDeviceGroupID="69"
mobileDeviceCommand="SettingsEnableDataRoaming"
# Mobile Device Commands:    #
# UpdateInventory            #
# BlankPush                  #
# SettingsEnableDataRoaming  #
# Full list:                 #
# https://developer.jamf.com #
deviceIDs=( $( curl -s -u "$jamfUser":"$jamfPass" $jamfProURL/JSSResource/mobiledevicegroups/id/$mobileDeviceGroupID -H "Accept: application/xml" -X GET | xpath "//mobile_device_group/mobile_devices" | /usr/bin/perl -lne 'BEGIN{undef $/} while (/<id>(.*?)</id>/sg){print $1}' ) )
for i in ${deviceIDs[@]}; do
    echo "Sending $mobileDeviceCommand to Device ID: $i..."
    /usr/bin/curl -sk -u "$jamfUser":"$jamfPass" -H "Content-Type: text/xml" -d "<?xml version="1.0" encoding="ISO-8859-1"?><mobile_device_command><general><command>$mobileDeviceCommand</command>></general><mobile_devices><mobile_device><id>$i</id></mobile_device></mobile_devices></mobile_device_command>" $jamfProURL/JSSResource/mobiledevicecommands/command/$mobileDeviceCommand -X POST > /dev/null
    if [[ "$?" == "0" ]]; then
        echo "   $mobileDeviceCommand Command Processed Successfully"
        echo "   $mobileDeviceCommand Error Processing Command"
    echo ""
done
