Posted on 03-09-2015 01:08 PM
I am using the setTimeServer.sh script provided by JAMF. When I look in /etc/ is see ntp.conf and when i vi ntp.conf it says in the file ; server time.apple.com
i'm on the east coast and it is set to west coast time and Cupertino, CA time zone
all other enrolled macs are getting the script fine and i do not see this log message for others.
On this one newly imaged mbpro I am getting the following log message.
Script result:
Setting network time server to: ntp.blobface.xxx...
2015-03-09 12:44:36.026 systemsetup[2384:507] ** -[ADMNetworkTimeClient _ntpSetEnabled:] /etc/ntp.conf doesn't exist. You need to create it first before ntpd can start sucesfully
setNetworkTimeServer: ntp.blobface.xxx
Network Time is already on.
Solved! Go to Solution.
Posted on 03-18-2015 10:10 AM
while that command does not return and error @stevewood i think if you actually look at /etc/ntp.conf you will see that its not a valid format
I am pretty sure that
server time.apple.com,myserver.abc.com
is invalid for ntp at least looking at some online documentation about it.
my link text
and running ntpq -p before and after seems to show the config as broken...
hpusmo001:~ etodnes$ ntpq -p
*time6.apple.com 17.107.131.11 2 u 330 512 1 40.224 0.550 2.011
hpusmo001:~ etodnes$ sudo systemsetup -setnetworktimeserver time.apple.com,mytimeserver.abc.net
setNetworkTimeServer: time.apple.com,mytimeserver.abc.net
No association ID's returned
Posted on 03-09-2015 01:30 PM
Not sure if there is anything different about that particular Mac but you could just add
touch /private/etc/ntp.conf
To the start of the script to make sure it's there.
Posted on 03-09-2015 01:49 PM
Try this:
# Use "/usr/sbin/systemsetup -listtimezones" to see a list of available list time zones.
TimeZone="America/New_York"
TimeServer1="internalserver.com"
TimeServer2="time.apple.com"
############# Pause for network services #############
/bin/sleep 10
/usr/sbin/systemsetup -setusingnetworktime off
#Set an initial time zone
/usr/sbin/systemsetup -settimezone $TimeZone
#Set specific time servers
/usr/sbin/systemsetup -setnetworktimeserver $TimeServer1
echo "server $TimeServer2" >> /etc/ntp.conf
# enable location services
/bin/launchctl unload /System/Library/LaunchDaemons/com.apple.locationd.plist
uuid=`/usr/sbin/system_profiler SPHardwareDataType | grep "Hardware UUID" | cut -c22-57`
/usr/bin/defaults write /var/db/locationd/Library/Preferences/ByHost/com.apple.locationd.$uuid LocationServicesEnabled -int 1
/usr/sbin/chown -R _locationd:_locationd /var/db/locationd
/bin/launchctl load /System/Library/LaunchDaemons/com.apple.locationd.plist
# set time zone automatically using current location
/usr/bin/defaults write /Library/Preferences/com.apple.timezone.auto Active -bool true
/usr/sbin/systemsetup -setusingnetworktime on
/usr/sbin/systemsetup -gettimezone
/usr/sbin/systemsetup -getnetworktimeserver
Posted on 03-09-2015 02:20 PM
Does Ntp.conf reflect what time server is set at? So would my Ntp.conf just say. Ntp.blobface.xxx ?
On the computers that have the script run correctly it is setting the time zone to my current location of Washington DC, which is correct and the time is correct
What is this echo line for?
Posted on 03-11-2015 08:48 AM
GaToRaid - on a computer or two I get the following information in the LOG after my policy runs that uses the script you provided. Have you seen this before? what does it mean? doesn't seem to harm anything anyways.
Script result: setUsingNetworkTime: Off
Set TimeZone: America/New_York
2015-03-11 11:18:24.362 system_profiler[10090:226920] platformPluginDictionary: Can't get X86PlatformPlugin, return value 0
2015-03-11 11:18:24.364 system_profiler[10090:226920] platformPluginDictionary: Can't get X86PlatformPlugin, return value 0
setUsingNetworkTime: On
Time Zone: America/New_York
Network Time Server: ntp.blobface.xxx
Posted on 03-12-2015 07:05 AM
@tcandela sorry for the delayed. Yes this error will be a problem since you are not enabling location services. Which OS are you running this on?
Posted on 03-12-2015 08:08 AM
Isn't the script enabling location services ? i see the check box checked in the 'privacy' section to enable location services. what problem is the log telling ?
these computers are mostly ethernet connected, in the TIME ZONE TABE it says 'turn on wifi to determine your current location'
I am running this on 10.7 10.8 10.9 10.10
so far on 32 computers that the script ran on, 3 computers got this message in the log
1 - MBAir 13" mid 2011 10.10.2
2 - iMac early 2009 10.10.2
3 - iMac (21.5-inch, Mid 2011) 10.10.1
also, on some computer after the policy with this script runs etc/ntp.conf lists both ntp servers
server ntp.blobface.xxx
while on others it lists just
and the system preferences date & Time has both time servers in the text box
ntp.blobface.xxx, time.apple.com
while on others it lists just ntp.blobface.xxx
Posted on 03-12-2015 08:15 AM
@tcandela ah you are right regarding the location services, we do turn that on with this script(sorry been at a conference for the last week, my head is a bit of mush.)
As for the issue that you are seeing is something to do with system profiler. Try running the command manually without the grep in it(i.e. /usr/sbin/system_profiler SPHardwareDataType) and see if you are able to return something.
And regarding the servers not getting listed, I would try and manually run the script one line at a time and see what results. I haven't had this issue before.
Posted on 03-12-2015 05:24 PM
From the command line What I get when running the /user/sbin/sysyem_profiler SPHardwareDataTpe is the same message as above, plus hardware overview information.
When I run it from the CL with Grep in it , I get the same two lines, plus a third line displaying the Hardware UUID
What is this line supposed to do?
Seems to be happening only on yosemite
Posted on 03-12-2015 05:45 PM
From CL When I run sudo server Ntp.blobface.xxx >> /etc/ Ntp.conf ( with or without sudo)
I get. -bash: /etc/Ntp.conf: permission denied
This is from 10.10.2. System
Posted on 03-12-2015 09:30 PM
should be something more like
sudo sh -c "echo ntp.blobface.xxx >> /etc/ntp.conf"
Posted on 03-13-2015 09:56 AM
nessts - I ran the command your provided from the CL on a computer that did not get both servers added to the ntp.conf file, and it worked
sudo sh -c "echo server ntp.blobface.xxx >> /etc/ntp.conf"
should i revamp the script section to what you see below?
CASPER doesn't need sudo so leave it out ?
also the quotes go from "server ..... .conf" ?
sh -c echo "server $TimeServer2 >> /etc/ntp.conf"
Posted on 03-13-2015 11:45 AM
well it all depends how and what you are trying to do.
running it from the command line is wholly different than doing it in a casper policy,
you do not need the sudo sh -c and the 2 "
I was just helping you fix your command line issue.
you don't even have to use sysetemsetup to do the first one if you don't want to. The script looked to be correct as it was.
Posted on 03-16-2015 06:33 PM
trying to figure out why this line works on some computers and not others
Posted on 03-16-2015 06:39 PM
@tcandela A better way to set time servers, time zone, etc:
systemsetup -settimezone America/Chicago
# enable network time
# set the time server
timeServer='time.apple.com'
systemsetup -setnetworktimeserver $timeServer
That's the method I use, and I haven't had a problem using that method since 10.6.
Posted on 03-16-2015 07:16 PM
I realized that you were trying to set two time servers. According to this discussion on JAMF Nation:
Best way to set multiple NTP servers in 10.7.x and 10.8.x?
You can use systemsetup and just put a comma between the servers:
systemsetup -setnetworktimeserver $timeServer1,$timeServer2
my link text
Posted on 03-18-2015 11:31 AM
Ah, right you are @nessts! I simply found that info in that discussion, and didn't verify the info was correct. Thanks for correcting me Todd!
Posted on 03-18-2015 11:34 AM
that is what I am here for trying to bring a little Unix sense to a Mac world. :)
