Hi Guys,
I have spent ages trying to get together a way of setting the screensaver to a company picture. I've tried scripts and Screensaver packages created in composer, configuration profiles, I can't seem to find a solution. Can someone suggest to me what might work? I will put the script I've been using down below just in case I'm doing it wrong.
currentUser=`ls -l /dev/console | cut -d " " -f 4`
# grab the system's uuid
if [[ `ioreg -rd1 -c IOPlatformExpertDevice | grep -i "UUID" | cut -c27-50` != "00000000-0000-1000-8000-" ]]; then
macUUID=`ioreg -rd1 -c IOPlatformExpertDevice | grep -i "UUID" | cut -c27-62`
jamf displayMessage -message $currentUser
defaults write /Users/$curUser/Library/Preferences/ByHost/com.apple.screensaver.$macUUID.plist CleanExit "YES"
defaults write /Users/$curUser/Library/Preferences/ByHost/com.apple.screensaver.$macUUID.plist PrefsVersion -int 100
defaults write /Users/$curUser/Library/Preferences/ByHost/com.apple.screensaver.$macUUID.plist idleTime -int 600
defaults write /Users/$curUser/Library/Preferences/ByHost/com.apple.screensaver.$macUUID.plist moduleDict -dict moduleName "iLifeSlideshows" path "/System/Library/Frameworks/ScreenSaver.framework/Resources/iLifeSlideshows.saver" type -int 0
defaults write /Users/$curUser/Library/Preferences/ByHost/com.apple.screensaver.$macUUID.plist tokenRemovalAction -int 0
defaults write /Users/$curUser/Library/Preferences/ByHost/com.apple.ScreenSaverPhotoChooser.$macUUID.plist LastViewedPhotoPath ""
defaults write /Users/$curUser/Library/Preferences/ByHost/com.apple.ScreenSaverPhotoChooser.$macUUID.plist SelectedFolderPath "/Library/Screen Savers/Default Collections/5-custom"
defaults write /Users/$curUser/Library/Preferences/ByHost/com.apple.ScreenSaverPhotoChooser.$macUUID.plist SelectedSource -int 3
defaults write /Users/$curUser/Library/Preferences/ByHost/com.apple.ScreenSaver.iLifeSlideShows.$macUUID styleKey "KenBurns"
killall cfprefsd
