As part of a general effort to become more knowledgable about AWS and JAMF, I've started a dummy environment totally separate from production for my own practice purposes, with the hopes of convincing my department head to implement them once I become more proficient/comfortable with the tech. I've played around a fair amount with policies/configuration profiles/etc, but when it comes to setting up a new server, especially in the cloud, I'm rather more of a newbie.
As part of my research I found an excellent blog post by John Kitzmiller (https://www.johnkitzmiller.com/blog/setting-up-the-jss-behind-an-elastic-load-balancer-in-amazon-web-services/) as well as one by auslin more focused on Elastic beanstalk rather than ec2 on its own (http://aulin.co/2017/Jamf/) but I've found myself getting stuck earlier on in the process.
I've tried installing the jamf pro 10.5 client both manually and using the installer. Since I only have to access the machine via terminal (the AMI is running ubuntu 16.04), I installed lynx to attempt to get up and running after the installer was completed. However, when going to localhost:8443 with lynx I get an error saying there is an insecure ssl cert (I generated a self signed one), and when i attempt to bypass lynx quits out with the error "can't access startfile localhost:8443", so I can't get into the web app to get through the rest of set up.
Has anyone run into something similar?
