- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
Posted on
04-22-2020
02:14 AM
- last edited on
03-04-2025
06:14 AM
by
kh-richa_mig
I have a test JAMF Pro server (10.20.1) on Red Hat that has the MySQL on another Red Hat server. It almost looks right but some odd things are happening
- machine searches in the web interface for all machines (nothing in the search field) bring zero results but if I search explicitly for a machine I know is in there by typing its name, I find it
- Accessing the API gives
<computers>
<size>0</size>
</computers>
so that agrees in a way to the first point.
Unfortunately it looks like this issue has been in there through several upgrades so restoring is probably not going to fix it. I'd like to get it back to a point that I trust it.
Given that it's a test server, would it be simplest to just blow away the database and recreate it? If that is the way, will the Tomcat server re-configure the database with all the tables as it does its first connection or do I have to re-do its installation too?
Regards,
David
Solved! Go to Solution.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Posted on 04-22-2020 03:22 AM
If you don't care about losing the data then yes, drop the database, create a new one and grant permissions. When tomcat is restarted it will recreate the tables. I am curious, when you do your computer search does the dropdown show that you're searching for computers?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Posted on 04-22-2020 03:56 AM
This sounds like an issue with the inventory. There could be a computer which does not have an UDID. Contact Jamf Support, they can send you a few MySQL commands to search for that device in the computers_denormalized
table.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Posted on 04-22-2020 06:52 AM
That first bullet just sounds like you do not have your Search Preferences set. By default computer searches are set to Exact Match.
Simple Computer Searches
Configuring Account Preferences
On the second bullet, about the API, what was the API endpoint you went to? If you go to https://{{url}}/JSSResource/computers
does it pull back your inventory?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Posted on 04-22-2020 05:47 PM
Hi @stevewood Good idea on the Search Preferences but they are set to the default on both prod and the test server for me. That is "exact match" for everything.
Dor the API I was just using the /api p[age but using it the way you asked gives the same result
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Posted on 04-22-2020 06:03 PM
Hi @anverhousseini Good suggestion. Not many computers in there so I listed the table and they all have a UDID.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Posted on 04-22-2020 06:06 PM
Hi @leslie Yes - the dropdown is set for computers but a good thought. I've been in the wrong area before with the search.
Ok - I guess I'll have to suffer the wrath of the DBA team :) and get them to drop the database and recreate a new one
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Posted on 04-22-2020 07:32 PM
I had a similar issue it was caused by one machine that was not updating inventory properly.
You could try loading each of the most recently enrolled computers 1 by 1 by going to
https://YOURJSS:8443/computers.html?id=<ID>&o=r&v=inventory
Changing YOUR JSS and ID for the appropriate values.
Look for any machines that dont have complete inventory and deleting them.
you can get the computer IDs from mysql by:
use jamfsoftware;
select computer_id from computers;
Also check your jamfsoftwareserver.log to see if its creating errors when performing searches.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Posted on 04-24-2020 01:44 AM
@leslie I went with the drop database and then create database route. For all you kind people who suggested troubleshooting steps - I thank you. I just need this test server for a short while and then we'll migrate to Jamf Cloud. Everyone is working really hard here and I am sure they are where you are too so I didn't want to waste our DBA's or JAMF Support time in troubleshooting (I am allowed to look in the database but not touch). It did take some time to reconfigure but In some ways I cleaned it up as well
Regards,
David
