Smart Group Based on IP Range.
  • April 29, 2020
  • 54 views
I'm attempting to create a smart group based on an IP range. so say for example I want everything under 11.9.x.x in a group. Any suggestions?
atomczynski11
Criteria: IP Address
Operator: Like
Value 11.9
Understand that once the device IP changes outside of the range the device will fall out of scope.
What are you trying to accomplish?
  • April 29, 2020
You would need to update the inventory whenever the IP changes, otherwise your SG will always be out of date and the scope wrong...
  • April 29, 2020
Hi @GiveEmHelms ,
If you are not already, I'd look into utilizing Network Segments in Jamf Pro. You can set a IP ranges and even assign them to different buildings or departments.
When you create a policy, you can select All Computers (Or another Smart Group) and then limit it to a selected Network Segment.
While Network Segments are not part of Smart Group criteria, you could associate the Network Segment with a Building or Department and create Smart Groups with Building or Department as your criteria. Just be sure to Override in Inventory if you select this approach:
