Smart group for out of date OS patches
k3vmo
Contributor II
How are you listing systems that are out of date?
I scope an update mechanism to a smart group for Catalina systems that are above 10.15.1 and are not build 19H15 - yet all of my Catalina systems show in the Smart group - not just the systems that need said security patch
I'd like to have a smart group showing all systems that aren't current for the OS build.
Suggestions on how to set it up?
1 REPLY 1
cbrewer
Valued Contributor II
It's not ideal but you can do it by getting familiar with regex and operating system build.
Example: Operating System Build matches regex ^19([A-G]d{1,4}|H([0-9]|1[0-4]))$
The regex gets more complicated as the build numbers grow in character length. It would be really nice if Jamf built this into the product.
