Posted on 03-14-2012 10:26 AM
I'm running 8.43 on a Lion server (that only runs JSS and SUS) and when I attempt to view a smart group in JSS it takes 5+ minutes if it loads at all. Any ideas on how to remedy this? The group in question only contains 9 machines.
Solved! Go to Solution.
Posted on 03-14-2012 12:43 PM
I had the same prob. DB Size 33 GB. Now with 2GB the JSS is much fast. Is it possible to activate "Flush Policy Logs"?
Posted on 03-14-2012 10:58 AM
how big is your DB?
Posted on 03-14-2012 11:12 AM
I have the same issues. I made a smart group yesterday and its still slowly updating today.
Posted on 03-14-2012 11:26 AM
Roughly 20gbs.
Posted on 03-14-2012 04:03 PM
I'll try flushing the logs over night and report back.
Posted on 03-15-2012 08:32 AM
Deleted a number of the older logs and now the JSS is running very smoothly and is quick to return smart groups and other data. Thanks for your help as always.
Posted on 10-29-2012 01:26 AM
Sorry to revive a dead thread, but I've found that you can add an extra index to the usage_logs table. I think this needs to be recreated every time the JSS is restarted, but it seems to do the trick every time I need to query a smart group:
CREATE INDEX `computer_mtime` ON `usage_logs` (`computer_id`,`date_entered`);
This does have the tradeoff that inserting new data may be somewhat slower, but it beats being unable to query smart group membership :)
