Snagit License Key issue
  • October 12, 2020
  • 61 views
We had got the license version of Snagit with license key of 30digit. so how to proceed with the packaging of the license version of this software in JAMF policy. As i had done packaging of the software and not getting how to package the License key so that when it pushed through policy the software should be license automatically. As i am new to this JAMF so not aware how to do the key mapping in MAC. In there is a way to check on the local system(i.e on MAC HD) where the software keys are located if we install the license software manually and manually putting the keys.
I am not see any files or plist is getting generator when we put the license key manually.
Appreciate some support on this.
1 reply
  • January 5, 2021
Hi, if you haven't already figured this out, try the info here: https://support.techsmith.com/hc/en-us/articles/115007344888-Enterprise-Install-Guidelines-for-Snagit-on-MacOS
