Posted on
10-03-2017
08:55 AM
- last edited
a week ago
by
kh-richa_mig
Is there any way I can sort users in JSS that are NOT assigned to an iPad?
Basically, I want to be able to filter out the usernames no longer tied to a device so I can remove them from displaying in Apple Classroom for that teacher's class. There aren't many options for smart user group criteria...
Posted on 10-03-2017 10:44 AM
@aaron.kelley You can create an advanced mobile device search and for criteria use 'Username' is and set it to blank. This will report iPads that dont have a username attached to it.
For comparison, the two below images show the devices that have a username assigned to it
If this isnt what you were actually looking for I appologize
Posted on 10-03-2017 11:26 AM
@miregan Hmm, while that's not exactly the wrong answer, it's not what I was searching for. I was actually looking for vice versa; an advanced search or smart group that showed me what users aren't assigned to a device and listed those in a filtered list RATHER THAN what mobile devices do/don't have a username and listed the devices.
In layman's terms, if a username isn't assigned to a mobile device, then filter it to an advanced search or smart group.
Posted on 10-03-2017 11:33 AM
@aaron.kelley Hmm well you can also create a smart advanced user search where the Username is not blank and have the display show mobile devices. You could then sort by the row and see how many users have 0 mobile devices attached them them. Other than those two ways I dont have know of a way to do what you want exactly unfortunately. This is the closest I could come up with. :(
