Spotlight not working after imaging (Target mode)
steventhemacman
New Contributor III
Imaging just fine, but Spotlight does not work after imaging. I am really new and am not sure how to write a script to fix this issue. I found another forum where they said to write a script containing:
rm /.metadata_never_index
rm /.fseventsd/no_log
Or another containing:
sudo rm -i .metadata_never_index
sudo mdutil -E -a -i on
I am not sure what the difference is, moreover I do not know how to create a script (really, but I am learning slowly). I see someone asking the same thing in the other post, but no one answered. I know it is probably simple, but the help would be appreciated. Also, once I make a script, I can put it in the image configuration I assume.
5 REPLIES 5
steventhemacman
New Contributor III
Oh, one more thing, I did try to make a script, and it kind of works, but it makes the imaging process hang at the (Casper is finishing imaging) window. If I shut the machine off it will finish up. If I delete the script it does not seem to do it (get stuck). What is funny is that it does fix the spotlight issue, just makes it a pain for imaging right now.
Matt
Valued Contributor
# Spotlight Fix
steventhemacman
New Contributor III
Thanks! I will give it a try, I was not to far off on the script making, pretty simple. I thought maybe I was missing something. Quick question, set as "after reboot"?
Matt
Valued Contributor
Yeah "At Reboot"
hkim
Contributor II
rm /.metadata_never_index rm /.fseventsd/no_log
That basically removes the offending files that prevents Spotlight for indexing the volume. This should be run as root.
Erases Spotlight database and then turns on Spotlight for all volumes.
