Spotlight slowing MB Air
  • February 13, 2014
  • 0 views
I imaged our student loan MacBook Airs with 10.9.1 and use Deep Freeze on them. Each time a user logs on, Spotlight starts indexing and slows the Mac to a crawl and drains precious battery power.
Is there a proper way to disable Spotlight so it doesn't run for each new user; and without causing other problems?
1 reply
  • February 13, 2014
Disable
launchctl unload -w /System/Library/LaunchDaemons/com.apple.metadata.mds.plist
Re-enable
launchctl load -w /System/Library/LaunchDaemons/com.apple.metadata.mds.plist
There is also an older method, which can sometimes cause problems:
mdutil -a -i off
