$string=$string | tr [a-z] [A-Z] no workie
  • May 23, 2016
  • 7 replies
  • 27 views
Hello!
I'm capturing text then echoing it to ALL CAPS like this, which proves the command works.
read diskName
echo $diskName | tr [a-z] [A-Z]
The goal is to pass this capitalized text to:
sudo diskutil partitionDisk /dev/diskn MBR fat32 "$diskName" 0b
However! My trouble is passing the ALL CAPS text to the diskutil command. So I tried:
$diskName=`"$diskName" | tr [a-z] [A-Z]`
Here's the whole piece:
read diskName
Any thoughts?
Best answer by davidacland
Hi @jfb
This one will work:
read diskName
sudo diskutil partitionDisk /dev/disk2 MBR fat32 $(echo $diskName | tr [a-z] [A-Z]) 0b
davidacland
  • May 23, 2016
Hi @jfb
This one will work:
read diskName
  • May 23, 2016
Just as an FYI, there's also awk
echo $diskName | awk '{print toupper}'
  • May 23, 2016
@davidacland
Can you explain the use of the parenthesis and how it did what I wanted it to do?
Thank you so much!
davidacland
  • May 23, 2016
My understanding is that they are mostly interchangeable, although the $() syntax is newer and preferred these days.
It's rare that I see an actual issue with the backtick syntax but this must be one of them.
  • May 23, 2016
Actually I don't think the issue is the use of backticks here (although the $() syntax is preferable since its easier to read and less prone to be confused) The problem is that when you do this:
You are not creating a new variable because $diskName isn't being echoed first to pass it to tr. IOW, tr isn't actually receiving the captured $diskName variable to run any conversion on it. if you just changed it like so:
$diskName=`echo "$diskName" | tr [a-z] [A-Z]`
it would probably work just as well as the one posted above.
  • May 23, 2016
@mm2270 is right the first is just sending the output of a command stored in $diskname to tr which is probably not a valid command and if it was it certainly wouldn't be what you were after.
Hey guys -
1st, I'm not sure if that 1st $ is part of the command or if it's just the prompt? Also, I agree I'm not sure I'm seeing the objective...
2nd, as to syntax, even bash version 3 which ships with OS X (the newest version is version 4...) refers to backticks as "the old-style backquote form of substitution". Bash Reference Manual
$(somecommand)
is preferrable. Also, something like:
name=$(echo "$inputname" | /usr/bin/tr '[:upper:]' '[:lower:]')
is preferable for transforming character classes. Good luck!
