Posted on
05-09-2018
09:42 AM
- last edited on
03-04-2025
06:40 AM
by
kh-richa_mig
Has anyone been able to deploy a 64 bit version of System Center Endpoint protection on High Sierra. We've downloaded the latest ISO from the MS enterprise site and the installer suggests that it includes both the 32 and 64 bit versions. However when I install via the DMG or the PKG contained within, it is showing that the 32-bit installed.
We're trying to roll out the 64 bit version before 32-bit support on OSX ends.
Posted on 05-09-2018 11:07 AM
We are seeing it show up as 32bit only as well. As far as I am aware 4.5.32.0 is the only version available at the moment and it is 32bit only according to https://macadmins.software/
If the trend follows, I'm guessing Microsoft will release an updated 64bit version 4 months after the latest OS release as they tend do with much frustration.
Posted on 05-10-2018 10:03 AM
Maybe we can be optimistic?
https://docs.microsoft.com/en-us/sccm/protect/deploy-use/endpoint-protection
"You should see several files, including one named: System Center Endpoint Protection (current branch - version 1606) for Linux OS and Macintosh OS Multilanguage 32/64 bit 1878 MB ISO."
I'm trying to get a copy of this for deployment in our environment. I'll circle back if I can get a 64-bit version.
