system preference restriction
  • July 12, 2022
  • 26 views
Hi
I am deploying some mac minis using Jamf school,
I am trying to disable some system preferences but it is not working,
none of the system preferences get disabled, i have tried
importing a mobile config file from
Jamf pro and profile creator still not working
the os version is 12.4
any ideas
AJPinto
  • July 12, 2022
What are you trying to disable specifically? Not everything can be disabled with configuration profile by Apple design. Some things that cannot be disabled can be hidden with a plist. It all depends on what exactly you are trying to manage.
  • July 12, 2022
Hi essentially just some system preferences, but school boy error i rebooted the mac and the restrictions worked, never had to do that before, i was used to send the profile you see the screen refresh and get the result but it seems you need to reboot 12.4 we live and learn
thanks
AJPinto
  • July 12, 2022
thanks
Oh, lol. Ya, when you drop new restrictions macOS needs to "update". You can also run sudo JAMF manage which should apply any new configurations that are "pending a reboot" to apply.
