Target Imaging not doing recon
queenwood
New Contributor
I started to use Target imaging from USB drive to improve speed of imaging. Using the same image as before, it does not seem to setup the CasperAdmin login (used for recon) or SSH settings for remote access.
I had to add the user name and ssh details manually so I can do a recon from the server. This did not happen when using the JSS as my source for image.
1 REPLY 1
tkimpton
Valued Contributor II
Hi David
Its probably because of localised imaging the machine cannot contact the jss to create accounts etc.
If I were in your shoes I would create a launch daemon using Lingon to run a script to create the Management account and another Launch daemon to run another script to turn on ssh for your specified account.
Ps possibly want to add in a line to delete the launch daemons at the end of the script.
Hope that helps :)
