Uninstall Connect Control Client for Mac
bwoods
Valued Contributor
Looking through the documentation, I couldn't find a way to easily remove the ConnectWise Control Client. Created the script below to help anyone who uses the app. Please add your control client's unique id where the "x's" are.
# Brandon Woods
# August 2021
# This script uninstalls the Connectwise/Screen Connect client. No reboot required.
# Unload Connectwise LaunchAgents
sudo launchctl unload /Library/LaunchAgents/connectwisecontrol-xxxxxxxxxxxxxxxx-onlogin.plist
sudo launchctl unload /Library/LaunchAgents/connectwisecontrol-xxxxxxxxxxxxxxxx-prelogin.plist
# Remove Connectwise LauchAgents
sudo rm -v /Library/LaunchAgents/connectwisecontrol-xxxxxxxxxxxxxxxx-onlogin.plist
sudo rm -v /Library/LaunchAgents/connectwisecontrol-xxxxxxxxxxxxxxxx-prelogin.plist
# Quit Connectwise Application
sudo killall ScreenConnect Client
# Remove Connectwise Application
sudo rm -rv /opt/connectwisecontrol-xxxxxxxxxxxxxxxx.app
# Check for remanants of Connectwise LaunchAgents
sudo ls -la /Library/LaunchAgents/screenconnect-*
exit 1
3 REPLIES 3
user-kMDjUsheqD
New Contributor
Looks good. Going to try it out. Do you know which plist is the one that opens to allow screen recording? We have a configuration profile that allows that and only want the user to enable it when we remote in but sometime even after remoting in it still continues to open even after approving. So I rather just remove it so it no longer prompts user to approve it.
bwoods
Valued Contributor
@user-kMDjUsheqD  I'm seeing the same thing on my side, which is why I haven't deployed it yet. I can't find any information about what control that prompt. I'll keep looking though.
JeffBugbee
New Contributor III
Thanks Brandon! This worked great.
