Posted on 05-14-2019 07:41 AM
I updated from 10.10 to 10.12 last night and immediately noticed that I was getting prompted for JAMFAgent wanting to access SystemUIServer and SystemEvents. I deleted the old configs, created new PPPC Configs using the PPPC Utility and uploaded them to JamfPro. I scoped them out to my group and was still getting prompted to allow JAMFAgent permission.
The versions on the laptops are correct, JAMFAgent and JAMF binaries are version 10.12.
The Profiles installed show the new versions of the configs.
Any ideas what I missed here?
Thanks in advance
Solved! Go to Solution.
Posted on 05-14-2019 08:59 AM
You want to whitelist the jamf.app located in
/Library/Application Support/JAMF/Jamf.app
Small note from the 10.11 release notes
Posted on 05-14-2019 09:06 AM
Thank you so much, I missed that in the release notes. (I honestly did read them)
Posted on 05-14-2019 10:15 AM
It should have been more prominent imo
