Hi Everyone,
We modified our AD binding in the JSS to use the UNC path. Initially, the thought was to allow a network home directory to be used when students/employees were logging in. This has worked in our testing. Going forward, we found some errors on some computers for those that are logging in.
The errors were simply, You are unable to log in to the user account _ at this time. There was a discussion about this here.
It appears, if you disable the UNC Path, this will correct this problem. The issue however doesn't appear for all users trying to log in.
Does anyone have a definitive answer whether we should be enabling the UNC path or not? If not, I will disable this across the board, but it is curious why some users can log in and others cannot.
Thank you in advance for your replies.
