Using ADCS connector with a Citrix Netscaler as a reverse proxy.
  • March 14, 2019
  • 26 views
We are currently running a pilot of jamf Pro in a large AD environment and use AD certificates for authentication to our internal wifi network. I have successfully used a configuration profile with an AD Certificate payload to deliver the certificate to our macOS devices. Works well.
We are testing the ADCS connector using a Citrix Netscaler as a reverse proxy, and can't get it to work. Question:
Does anyone have any experience using a Netscaler as a reverse proxy for the ADCS connector? I've read all of KMerendaTFMC's great posts on using the F% just need some more specifics on the Netscaler.
If you do, I would to chat ;-)
  • January 31, 2020
We are trying with both Azure APP proxy and netscaler, but can´t get it to work. Did you manage with your netscale solution?
SteveS
  • August 18, 2022
What was your final solution to this challenge?
