Posted on 10-23-2014 04:13 AM
All of our users have a home directory with the same structure. e.g. within the root there is a Documents and Desktop folder, which if they log into Windows systems is automatically redirected and Offline Files takes care of Sync.
I'd like to replicate this on the Mac so when a user logs in their network Desktop and Documents folders are synchronized with the network share. The root of the network share is automatically mounted on OS X as part of their mobile account.
Looking at the Sync Rules I am not quite sure what to enter, as I would have expected something like a source and destination field but there only the ability to add a path. So, if I wanted to sync homedesktop to the local desktop what would I need to do?
Thanks
Solved! Go to Solution.
Posted on 10-23-2014 07:34 AM
This topic has been brought up before but it never really went anywhere. The homesync feature was deprecated by Apple with 10.6 and I personally haven't seen any other attractive options.
Is anyone still using home sync in 10.9+ and find it to be working reliably?
https://jamfnation.jamfsoftware.com/discussion.html?id=9637
Posted on 10-23-2014 07:36 AM
Ah right I didn't realise it was deprecated...thanks
Posted on 10-23-2014 07:41 AM
I wish it was deprecated enough there was a setting I could fully disable it via config profiles. Right now we do our best setting it to not sync any folders, but still when our mobile users login some small pref files are written to their home directory. Ticket with Apple said this was because our home directories mount via AFP. Will see what 10.10 brings I guess.
Posted on 10-23-2014 07:54 AM
We have been using Home Sync since 10.8 and now migrating staff to 10.10 with no issues to report. I use a script to mounts the user "H" drive at login and also provided the script in Self-Service when they are connected via VPN.
Posted on 10-24-2014 03:19 AM
@LuisT it's good to see someone having a good experience with homesync. I may need to go back and give it another look.
I was looking through old jamfnation posts and saw one user recommended using http://synkron.sourceforge.net I haven't tried it myself yet but thought I would pass it on.
Posted on 10-30-2014 02:57 AM
We are using Unison:
http://www.cis.upenn.edu/~bcpierce/unison/
And are very happy. It's superfast, stable and effective.
Posted on 04-18-2018 09:39 PM
"When I tried to do some serious copying during restoring operations, I discovered that the integrated Windows 7 copy function was practically useless. I was even more surprised to find, after some research, that it was a widely acknowledged fact among power users and developers.
If you want to copy or move thousands of files, big files or critical files, Windows Explorer is ridiculously inadequate.....third party software is good for use to copying large numbers of files, currently i am using GS rich copy 360 enterprise which has features like copying long file path names, copying NTFS file permissions and is not too costly.."
