VLC 2.2.5.1 isn't quitting using our script that works for older versions
donmontalvo
Esteemed Contributor III
We've been using @mm2270's script for quite some time, it works great.
But for some reason won't quit VLC 2.2.5.1 (quits older versions without a problem).
Here is the script, the process name is VLC as per Activity Monitor:
# Kudos to @2270 on Jamf Nation.
# EXACT process name (if multiple, carriage return between each)
PROCESSES=("VLC")
# Exact application path.
APPLICATION=""
# Do not edit between these two lines ---------------------------------------------------
for PROC in "${PROCESSES[@]}"; do
        RUNNING_PROCESSES=$(ps axc | grep -i "$PROC" | awk '{print $1}')
        if [[ $RUNNING_PROCESSES ]]; then
                echo "Found running process $PROC with PID: ${RUNNING_PROCESSES}. Killing it..."
                kill $RUNNING_PROCESSES
                echo "$PROC not found running..."
done
# Remove application
# /bin/rm -rf "$APPLICATION" 2> /dev/null
Any ideas?
https://donmontalvo.com
6 REPLIES 6
ryan_ball
Valued Contributor
First try a ps -ax | grep -i vlc to get the name of the process.
Not at my Mac right now to see the process name.
donmontalvo
@ryan.ball thanks, yes it does find the PID (confirmed in Activity Monitor):
$ ps -ax | grep -i vlc | grep -v grep
81407 ??         0:01.21 /Applications/VLC.app/Contents/MacOS/VLC
tlarkin
Honored Contributor
Maybe try using bundle ID to quit the app?
tlarkin
Honored Contributor
PIDs can get messy, especially with sand boxing, I have swapped all app quitting to use Bundle IDs
#!/usr/bin/python
from Cocoa import NSRunningApplication
BID = "org.videolan.vlc"
def quit_app(bid):
    apps = NSRunningApplication.runningApplicationsWithBundleIdentifier_(bid)
    if apps:
        for app in apps:
            app.terminate()
quit_app(BID)
donmontalvo
@tlarkin wow, nice...works if invoked as current user!
tlarkin
Honored Contributor
Yup, this is why the Objective C bridge in Python is very powerful
