Posted on 01-03-2016 08:25 AM
hi,
we use the netboot/sus appliance (version 3) under ubuntu 12/vmware esx.
since last week we can't login anymore to the webinterface.
webadmin/webadmin should work and also the AD-credentials of all persons in our it-department, but nothing works anymore for login.
I still can login via ssh with the user "shelluser".
can I reset the password of the account webadmin? or is there a logfile, perhaps I can see there why login doesn't work anymore.
I would like to avoid to setup a new vm and download all updates again.
many thanks,
regards, ferdinand
Posted on 01-03-2016 11:40 AM
Check the space on the allocated disk, i have found that previously that when the disk becomes full you are unable to log into the gui.
Posted on 01-06-2016 12:29 PM
hi TimC,
many thanks - that was the problem, I deleted some files and now I can login again!
regards, ferdinand
