Whitelist to prevent System Extension blocked
  • February 4, 2019
  • 5 views
Jamf system not yet online.
Is it possible to whitelist certain installers so they don't get the 'System Extension blocked'
1 reply
Forum|alt.badge.img+15
  • February 4, 2019
@k3vmo Yep, you can use the Kernel Extension Policy config profile to whitelist apps at your org. The Mac just needs to be in DEP (or in a user-approved MDM state).
https://derflounder.wordpress.com/2018/04/12/whitelisting-third-party-kernel-extensions-using-profiles/
