Posted on 06-16-2020 10:14 AM
So I have a provisioning sequence that happens to all mac enrolled via DEP. The issue is once the configuration profiles that installs the WiFi 802.1X certificate is also set to auto-join and it breaks the continuation of the installation of the reset of the applications. I was wondering if any one has any suggestion that could assist me. I need to auto-join at some point to the WiFi network. Thanks
Posted on 10-26-2020 02:10 AM
Yup i've run into a similar issue especially on device we are re-enrolling that have existing JAMF computer records. JAMF is applying configuration profiles based on the old inventory data of the device, so even though i have the 802.1X profile scoped to smart group so it doesn't occur during enrolment it still gets applied. The funny thing is we don't see this is a more heavily loaded JAMF instance due to the performance of the platform.
Posted on 10-26-2020 04:49 AM
https://www.jamf.com/jamf-nation/feature-requests/9840/802-1x-auto-join-profiles-break-jamf-enrolment-process
Posted on 11-03-2020 05:43 AM
I found a workflow that works! extension attributes can be cleared at re-enrolment, i excluded all devices which had the specific attribute as blank. This bought enough time for that first recon to run and the correct scoping to apply!
Posted on 11-02-2023 09:07 AM
Hello @Key1, I know this is a very old post but I'm curious what you ended up using for a workflow to get around this issue. We are seeing the same issue when our wifi profile is applied while enrollment and breaks delivery of jamf binary and self service etc.
Posted on 11-02-2023 11:50 AM
I believe it was just as simple setting the re-enrollment setting to clear ext attributes and then if a ext attribute i know is never blank is blank excluded it from the profile this allows the first recon to run first before devices become in scope of the profile.
