wireless setup script for 10.7.5
speterson
New Contributor II
hello,
getting ready to reimage machines this summer and I'm running into a problem with my network script. i have a 10.7.5 vanilla image created with instadmg, and i have the scrip set to run at reboot as part of a configuration profile with casper imaging (version 8.7) (witch is what i had it set at with my 10.7.2 image and worked correctly). i go through the setup assistant and then log on it doesn't seem to work, ill include the script below, any ideas??
thanks for the help
Shawn Peterson
Assistant Technology Coordinator
North Fayette CSD
West Union, IA
# Copyright (c) 2010, JAMF Software, LLC.  All rights reserved.
#       Redistribution and use in source and binary forms, with or without
#       modification, are permitted provided that the following conditions are met:
#               * Redistributions of source code must retain the above copyright
#                 notice, this list of conditions and the following disclaimer.
#               * Redistributions in binary form must reproduce the above copyright
#                 notice, this list of conditions and the following disclaimer in the
#                 documentation and/or other materials provided with the distribution.
#               * Neither the name of the JAMF Software, LLC nor the
#                 names of its contributors may be used to endorse or promote products
#                 derived from this software without specific prior written permission.
#       THIS SOFTWARE IS PROVIDED BY JAMF SOFTWARE, LLC "AS IS" AND ANY
#       EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED
#       WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE
#       DISCLAIMED. IN NO EVENT SHALL JAMF SOFTWARE, LLC BE LIABLE FOR ANY
#       DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES
#       (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES;
#       LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND
#       ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT
#       (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS
#       SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
# SUPPORT FOR THIS PROGRAM
#       This program is distributed "as is" by JAMF Software, LLC's Resource Kit team. For more
#       information or support for the Resource Kit, please utilize the following resources:
#               http://list.jamfsoftware.com/mailman/listinfo/resourcekit
#               http://www.jamfsoftware.com/support/resource-kit
#       Please reference our SLA for information regarding support of this application:
#               http://www.jamfsoftware.com/support/resource-kit-sla
# ABOUT THIS PROGRAM
# NAME
#   setAirPortNetwork.sh -- Disassociates from the current wireless network and sets the SSID and WEP or
#                    WPA password on the AirPort assuming the AirPort is on
# SYNOPSIS
#   sudo setAirPortNetwork.sh
#   sudo setAirPortNetwork.sh <SSID> <password>
# DESCRIPTION
#   This script was designed to configure the AirPort network settings, including which SSID the
#   AirPort is pointed to, as well as what password should be used to connect to the network
#   if the network is a secured wireless network.
# HISTORY
#   Version: 1.1
#   - Created by Eric Krause on March 5th, 2010
#   - Modified by Eric Krause on June 22, 2010 to fix the command for 10.5
# DEFINE VARIABLES & READ IN PARAMETERS
# HARDCODED VALUES SET HERE
SSID="Student"                    #The SSID of the wireless network to connect to
password="studentpassword"                #This only needs to be set if a password is required
# CHECK TO SEE IF A VALUE WERE PASSED IN FOR PARAMETERS $4 THROUGH $5 AND, IF SO, ASSIGN THEM
if [ "$4" != "" ] && [ "$SSID" == "" ]; then
    SSID=$4
if [ "$5" != "" ] && [ "$password" == "" ]; then
    password=$5
# SCRIPT CONTENTS - DO NOT MODIFY BELOW THIS LINE
if [ "$SSID" == "" ]; then
echo “Error: The parameter ‘SSID’ is blank. Please specify a SSID.”
exit 1
OS=`/usr/bin/sw_vers -productVersion | /usr/bin/colrm 5`
wifiDevice=`/usr/sbin/networksetup -listallhardwareports | awk '/^Hardware Port: Wi-Fi/,/^Ethernet Address/' | head -2 | tail -1 | cut -c 9-`
case $OS in
10.4*)
    echo "Setting airport SSID to" $SSID
    System/Library/PrivateFrameworks/Apple80211.framework/Versions/Current/Resources/airport -z -A"$SSID" –password="$password"
10.5*)
    /System/Library/PrivateFrameworks/Apple80211.framework/Versions/Current/Resources/airport -z -A"$SSID" –password="$password"
10.6*)
    echo "Setting airport SSID to $SSID..."
    /usr/sbin/networksetup -setairportnetwork AirPort "$SSID" "$password"
10.7*)
    checkWireless=$(networksetup -listallhardwareports | egrep "Hardware Port: (Air|Wi-)" | cut -c 16-)
    # First we need to get the Wi-Fi device's name
    /usr/sbin/networksetup -setairportnetwork "$wifiDevice" "$SSID" "$password"   ;;
esac
2 REPLIES 2
tkimpton
Valued Contributor II
Have a look at this specifically looking at wservice variable to specify the wservice.
Pick bit out you need from it and you wouldn't need different arguments for different the different OS
https://jamfnation.jamfsoftware.com/discussion.html?id=5327
tkimpton
Oh scroll down to the answer in the post i referred to, it's quite a long one.
