Posted on 10-20-2014 07:21 AM
For all previous operating systems, kerberos has worked to allow my login script to call mount_smbfs and mounted the drive properly. On Yosemite, when i use the same mount_smbfs command, I get prompted for a password. Any ideas?
At login, my script essentially runs:
/sbin/mount_smbfs //domain/path/share /Users/rhs615/Folder
And now terminal replies: Password for domain:
Running kinit, entering the password, and re-running the script does not appear to work even with a valid Kerberos ticket in Ticket Viewer.
Thanks in advance!
Posted on 10-20-2014 08:43 AM
I found this in examples section of the Apple Dev man page for mount_smbfs(8) https://developer.apple.com/library/mac/documentation/Darwin/Reference/ManPages/man8/mount_smbfs.8.h...
This example shows the proper url to use to mount the share PUBLIC from the SMB server myserver as guest: ``` mkdir /smb/public mount -t smbfs //guest:@myserver/PUBLIC /smb/publicNote: You should always use the system mount command and never call mount_smbfs directly.
Does using ```
mount -t smbfs
work at all in your environment in place of calling mount_smbfs directly?
