Yosemite AppleID and Diagnostic screen removal
tim_rees
Contributor
Hi All,
this one follows on from https://jamfnation.jamfsoftware.com/discussion.html?id=4920
I found there is now two more plist entries to write to remove the diagnostic and usage windows: DidSeeSyncSetup and DidSeeSyncSetup2 (original hey!)
The script now looks like this:
# Determine OS version
osvers=$(sw_vers -productVersion | awk -F. '{print $2}')
sw_vers=$(sw_vers -productVersion)
# Checks first to see if the Mac is running 10.7.0 or higher.
# If so, the script checks the system default user template
# for the presence of the Library/Preferences directory.
# If the directory is not found, it is created and then the
# iCloud pop-up settings are set to be disabled.
if [[ ${osvers} -ge 7 ]]; then
for USER_TEMPLATE in "/System/Library/User Template"/*
do
defaults write "${USER_TEMPLATE}"/Library/Preferences/com.apple.SetupAssistant DidSeeSyncSetup -bool TRUE
defaults write "${USER_TEMPLATE}"/Library/Preferences/com.apple.SetupAssistant DidSeeSyncSetup2 -bool TRUE
defaults write "${USER_TEMPLATE}"/Library/Preferences/com.apple.SetupAssistant DidSeeCloudSetup -bool TRUE
defaults write "${USER_TEMPLATE}"/Library/Preferences/com.apple.SetupAssistant GestureMovieSeen none
defaults write "${USER_TEMPLATE}"/Library/Preferences/com.apple.SetupAssistant LastSeenCloudProductVersion "${sw_vers}"
done
# If so, the script checks the existing user folders in /Users
for USER_HOME in /Users/*
do
USER_UID=`basename "${USER_HOME}"`
if [ ! "${USER_UID}" = "Shared" ]
then
if [ ! -d "${USER_HOME}"/Library/Preferences ]
then
mkdir -p "${USER_HOME}"/Library/Preferences
chown "${USER_UID}" "${USER_HOME}"/Library
chown "${USER_UID}" "${USER_HOME}"/Library/Preferences
if [ -d "${USER_HOME}"/Library/Preferences ]
then
defaults write "${USER_HOME}"/Library/Preferences/com.apple.SetupAssistant DidSeeCloudSetup -bool TRUE
defaults write "${USER_HOME}"/Library/Preferences/com.apple.SetupAssistant GestureMovieSeen none
defaults write "${USER_HOME}"/Library/Preferences/com.apple.SetupAssistant LastSeenCloudProductVersion "${sw_vers}"
chown "${USER_UID}" "${USER_HOME}"/Library/Preferences/com.apple.SetupAssistant.plist
done
1 REPLY 1
pcrandom
Contributor
This looks like a script Rich Trouton came up with a few months ago.
Rich has since created a script that allows you to set the preferences you wish and suppress the Diagnostics & Usage screen.
