Posted on 12-11-2014 11:57 AM
Recently we've had issues with people on Yosemite running into slowness and crashing issues. Were working with Apple on this and it seems to be a known issue. Apple says it's related to Active Directory and FileVault. So we're looking at disabling FileVault and Active Directory to try to help our users until Apple can find a fix.
So in trying to decrypt FileVault from yosemite machines we run into an interesting issue. When a user tries to log in with their Active Directory credentials they get an error message saying: "Your administrator requires that you enable FileVault. You must enable FileVault now to continue." The only option they have is to re-encrypt, but that doesn't help us here. Were currently using Individual FileVault method. The only FileVault user is the user themselves.
Doing further testing I found that this only occurs on Yosemite machines. When I try to decrypt a 10.8 or 10.9 machine I can log in fine with my Active Directory record.
Have you guys seen this error? Are you guys able to decrypt the machine?
Posted on 12-11-2014 12:02 PM
What policy is in place to force encryption on them? Do you have a Configuration Profile on them with the FileVault payload set up? It sounds like something you've pushed to those Macs is just doing exactly what you told it to. OS X by itself isn't going to enforce FileVault 2 on itself. That only comes from a managed profile or some other setting.
Yosemite in particular now has an option that can be enabled with a config profiles to force FileVault encryption at login, which is what it sounds like is happening.
Posted on 12-11-2014 12:12 PM
We currently have a policy that runs when a new user logs/startup/recurring. What this policy does is run a script. The script checks to see if they user is bound to active directory and if so, runs the manual trigger for the policy that deploys the actual encrpytion. The reason we do this is because we have the users set up a admin account and then use and enroll url. We didn't want the FV to activate on their admin account, only on the active directory account.
The encryption policy is set to run once per computer, apply desk encryption configuration, fileVault 2 Individual, and require it at next logout.
We didn't really see this issue until recently so at first I was thinking it might be Casper related since we updated to 9.61...but I haven't found any evidence of this yet. I have a support case with both Apple and JAMF on this. But wanted to see if anyone else in our community has seen this.
Posted on 12-11-2014 04:03 PM
We see the same thing, but it is what we want. : )
User logs in 1st time and a launchd trigger a scrip that call a manual trigger/event for FileVault that script forces a reboot. The next time the user logs in we see that "Your administrator requires that you enable FileVault. You must enable FileVault now to continue." pop up. Then we use a Config Profile to prevent the users from decrypting.
I have not decrypted a machine yet, I assumed that the "Your administrator requires that you enable FileVault. You must enable FileVault now to continue." pop up would only work once with a deferred FV trigger/event.
Next time I have a test machine that I can decrypted, I'll follow up : )
C
Posted on 12-11-2014 04:17 PM
Ideally, its what we would want too since it would force Filevault and would make compliance a lot better. But since Yosemite is causing issues and Apple has asked up to remove FileVault for testing...would be nice to be able to do it.
I was also looking into the JAMF documentation about FileVault and realized that with Yosemite their method wouldn't work on an Active Directory Machine. They basically have you:
1) Go into recovery partition
2) Go into terminal and unlock and decrypt hard drive using recovery key
3) Reboot when done and go into recovery partition.
4) Use the reset password app to change the users password.
Since the user is still Active Directory, it would essentially still pop up that error message. So potentially this is even a bigger issue since when a person leaves, we have to e-discover their machine. In order to e-discover we need to decrypt it...and log in as the user. So catch 22 there.
Glad to see at least someone else is seeing that message though.
Posted on 12-11-2014 05:02 PM
Roie,
I should have added that we have seen slowness and freezing issue with our older 2011 MBP that are HHD based. We have not seen it on the newer MBPr that have "SSD".
C
Posted on 12-12-2014 03:52 AM
C,
A couple of our users have the SSD drives and are having the issue. In my research I've found several different angles people are looking at:
1) Filevault and Active Directory (as claimed by Apple)
2) Energy Savings settings, since issues seem to to occur after waking up the laptop.
3) iCloud Disk usage. I found this out myself when at the JAMF conference. My hotel has really bad WIFI and the iCloud Disk was pegging the CPU at 120% and made the computer unusable. After shutting it off, it worked fine.
So will add hard drive type to the list and check as well. I have extension attributes written for all the possible causes mentioned above so I can keep track of problem machines and see if their attributes are similar.
Posted on 12-15-2014 06:49 AM
few people have been having similar problems, this workaround is working for the 4 or so macs that have had the problem in my environment
https://jamfnation.jamfsoftware.com/discussion.html?id=12188
Posted on 12-15-2014 05:06 PM
Roie,
Yep, after we decrypt we still see the "Your administrator requires that you enable FileVault. You must enable FileVault now to continue." pop up.
Have you reached out to JAMF? Can you provide me with your Apple tix # ....I will reach out to our Apple guys and open a ticket too..
C
Posted on 03-10-2015 09:22 AM
I have been able to get around this pop-up by deleting the following entries, after turning FileVault2 off and before rebooting the machine once the decryption process is complete:
/Library/Keychains/FileVaultMaster.cer
/Library/Keychains/FileVaultMaster.keychain
Once removed, I no longer see the pop-up and I run a "sudo fdesetup status" after login to confirm that FV2 is disabled.
At the moment, this is a manual process for me as I am only removing FV2 for a handful of users.
Hope this helps.
Posted on 04-23-2015 02:58 PM
I am seeing this same issue as well with Yosemite 10.10.3 and came across this thread in my research. We do a deferred enablement through Self Service so I know there is no policy getting automatically reapplied since I have to trigger it manually.
I found that after disabling FileVault through the system preferences if I hit Cancel when I get the "Your administrator requires that you enable FileVault. You must enable FileVault now to continue." message and login with our local admin account it does let me get in without enabling FileVault. If I then go to the terminal and run fdesetup status I get the following:
FileVault is Off. FileVault master keychain appears to be installed. Deferred enablement appears to be active for user 'USERNAMETODEFERHERE'.
I also found that if I run sudo fdesetup showdeferralinfo I get the following (some info has been sanitized):
{ AskAtUserLoginMaxBypassValue = 0; CertPath = stdin; Certificate = <CERTIFICATEINFOHERE>; Defer = 1; DontAskAtUserLogout = 1; OutputPath = "/Library/Application Support/JAMF/run/file_vault_2_recovery_key.xml"; Usernames = ( USERNAMETODEFERHERE ); }
USERNAMETODEFERHERE is the same user that was enabled for FileVault when it was initially enabled on the Mac with the issue.
Since I have had no policies run for this Mac after disabling FileVault and since others said this issue started appearing in 10.10 I am wondering if there is some OS X or Casper bug where the deferment information is not getting removed after FileVault has been successfully enabled via policy for the user specified for deferred enablement.
Reading through the fdesetup manpage I found that I can remove the deferral by running sudo fdesetup disable even though it is already disabled. It will tell you "FileVault is already Off." but when you run sudo fdesetup showdeferralinfo again it now returns "Not found."
Posted on 07-21-2015 06:12 AM
Thank's @mmunoz2 and @spalmer! I run into the same problem: FW2 was manually deactivated but the encryption needed to be activate again at each logout (was manually canceled every time). fdesetup disable did the trick, no need to trash the FileVaultMaster.keychain.
apfelpom:~ yb$ sudo fdesetup status
FileVault is Off.
Deferred enablement appears to be active for user 'yb'.
apfelpom:~yb$ sudo fdesetup disable
apfelpom:Keychains la$ sudo fdesetup showdeferralinfo
Not found.
Posted on 11-19-2015 05:57 AM
Hi Group! Thanks for everyone's insight on all of this. So far so good with the 'decryption' of FV2. We were going bald over here trying to figure all this out. One thing though... when we check the status of fdesetup, we see that FV is finally off but 'FileVault master keychain appears to be installed'. I know where this file lives (Library/Keychains). Okay to delete/remove this? Or should we just leave it be to not screw anything else up?!?
Posted on 02-05-2016 11:16 AM
I had success preventing FileVault 2 from requiring enabling after unenrolling the computer, removing:
and ONLY after removing the JAMF folder located:
Then, when I rebooted the computer, it didn't require FileVault 2.
Posted on 09-07-2017 07:55 AM
I am encountering the same issue on my 10.12.6 machine, but the above solution is not working. But my conditions to arrive here were slightly different:
I first checked all Jamf policies to ensure there was nothing set to run on startup or login regarding FV. There wasn't - there is only an ongoing policy in Self Service to allow users to enable FV themselves, and a policy to redirect FV keys to the JSS. To be safe, I still added exceptions to these policies for my computer and tried again, but still the same behavior.
I unenrolled the computer from Jamf, confirming /Library/Application Support/Jamf and /Library/Keychains/FileVaultmaster.keychain were removed
Considering there is no policy running on the Jamf side to force FV on, the FileVaultMaster.keychain file is gone, and I'm not even enrolled in Jamf, what else would be prompting this to turn on when I reboot?
