Posted on 01-14-2025 06:40 AM
Hi everyone,
Since the update of JAMF Connect to V2.43.0 we've had a couple of devices getting an error messages saying that "JAMF Connect is Damaged and can't be opened." On investing this further we have found that "JAMF Connect was blocked from use as it is not from an identified developer." I'm curious why this would be.
Posted on 01-14-2025 06:58 AM
Question. Are you downloading the package from your JMF Account and uploading. Or are you using the upgrade method straight from JPS. I'm very curious, has I myself have not run into this issue with our deployment.
Posted on 01-14-2025 07:18 AM
@Wakko The package is being updated by the JAMF app catalog.
Posted on 01-16-2025 11:10 AM
@naheem_iqbal that is so strange. I just [re]enrolled a device that has base install of JAMF Connect 2.40, which was updated to version 2.43.0. Via the auto-mated process. I would reach out to support for additional assistance.
Posted on 01-22-2025 10:44 AM
What I should have noted was that we were intially deployiong and old version which was then getting updated via JAMF App catalog to the latest version. I have uploaded the latest version to the pre-stage enrolment and have had no further issues reported. I still question why the upgrade as it was was getting blocked by gatekeeper..
Posted on 03-17-2025 09:06 AM
GateKeeper blocks apps, including Microsoft Office. The affected app varies, and the solution is to allow it through Privacy and Security > Security.
