Posted on 02-02-2022 01:35 AM
I'm looking at integrating some Macs with Azure AD. I had a call with a Jamf sales guy today about Connect and he mentioned there was a feature that in Connect that didn't work without using Jamf Pro as well. Something to do with local account / password synchronization with Azure AD. Does anyone have an idea what that is?
We already use Intune as our MDM, so I don't plan on shelling out money for another MDM solution as well.
Posted on 02-02-2022 05:55 AM
You can probably use the free product NoLOAD and NoMAD... and integrate that with your current SSO.
I would test to ensure all is working well before moving to production use.
Hope this helps and good luck.
Posted on 02-02-2022 07:19 AM
@akhilsete I believe Jamf Connect and Jamf Connect Login apps rely on Jamf Pro for deployment, management, etc. and cannot be used independently, NoMAD is a great option to checkout.
I see you mentioned Intune is your MDM for Macs, what has that experience been like, it is not very often I see that used as the primary MDM and am interested in thoughts around it?
