Posted on 07-11-2019 08:49 PM
We're setting up NomadLogin for deployment and I'm testing right now. The AD connection is working, but all I get for the background and logo are white screen.
I don't know where I'm messing up. Here's my script:
# Preference key reference
# https://gitlab.com/orchardandgrove-oss/NoMADLogin-AD/wikis/Configuration/preferences
domain="rbschool.org"
background_image="/rbsimages/nomadback.jpg"
logo="/rbsimages/nomadlogo.png"
# Set default AD domain
defaults write /Library/Preferences/menu.nomad.login.ad.plist ADDomain "$domain"
# Set background image
defaults write /Library/Preferences/menu.nomad.login.ad.plist BackgroundImage "$background_image"
# Set login window logo
defaults write /Library/Preferences/menu.nomad.login.ad.plist LoginLogo "$logo"
# Set security authorization database mechanisms with authchanger
/usr/local/bin/authchanger -reset -AD
# Kill loginwindow process to force NoMAD Login to launch
/usr/bin/killall -HUP loginwindow
Any help is greatly appreciated.
Solved! Go to Solution.
Posted on 07-11-2019 08:57 PM
Hi , check preferences on files you are using. they should be rw-r-r or 644. Also you can set those setting with a profile using profile creator
Posted on 07-15-2019 02:39 PM
@Nix4Life Thanks for your reply. we're beta testing the setup before deploying. I may be being daft (it is monday), but what is profile creator?
Posted on 07-16-2019 10:36 AM
this is profile creator. You need to make sure, apart from the images actually being there that the perms are correct as mentioned. I also find that some images work and some don't, never really delved into the actual formats too much but try smaller or less pixel depth usually helps.
Posted on 07-16-2019 10:51 AM
I would also specify BackgroundImageAlpha to 0.
Posted on 07-16-2019 12:17 PM
Double check that the path you're pointing at, is where the files actually are. According to your script the images are located at Macintosh HD/<here>. Is that where you want them? Would a /Users/Shared location be better? Are they hidden? What are the permissions, like @Nix4Life said?
Posted on 07-23-2019 02:15 PM
got it to work. had to reset permissions to 644. they got messed up in install somehow.
thanks!
Posted on 06-08-2021 02:31 PM
The composer app will also set the perms on the image files. I set mine to 744 and all went well.
