Device will not rejoin configured network
Torlok
New Contributor
Hey, new to Jamf and Configurator, been working though it through trial and error and all has been well for the most part
I recently set some iPads up for forcing a passcode to be used but all of a sudden after a day or so, all of the iPads this was pushed through were no longer reconnecting automatically to the wifi I setup a payload config profile for? Wifi was turned on, however nothing was showing in the listed networks... and since it wasn't joined to wifi, I couldn't do anything via Jamf
Is this a common issue and is there an easy resolution other than (what I assume is the only way to remedy this) not forcing an auto-join to a particular network?
1 REPLY 1
AJPinto
Valued Contributor III
I have never seen this myself. You may want to get a lightning/USB-C ethernet adapter, wiring the iPad up should allow it to talk with JAMF. I always fall back to a wired network when troubleshooting anything network related.
WiFi Logging Instructions (apple.com)
