Posted on
02-22-2021
01:25 PM
- last edited
2 weeks ago
by
kh-richa_mig
This is a small issue, but how 10.27.0 handles the Self Service Branding Header is not ideal for any company branding. Resizing the Self Service window distorts any image you have there. Not sure how this made it out of QA.
Posted on 02-23-2021 01:58 AM
I want the old one back...
Posted on 02-23-2021 03:26 AM
1000% agree with this. Not ideal at all especially when your background is of an actual object or a person/thing as opposed to just a random pattern or solid color/gradiant.
Posted on 02-23-2021 11:20 AM
Glad to see I'm not the only one with this issue. It's bumming my marketing team out.
Posted on 02-23-2021 11:26 AM
Branding needs a real overhaul. As in, things like unique branding for Sites or other criteria as many companies now have multiple logos and it's too limited as-is...
Posted on 02-23-2021 01:03 PM
I like the new layout in general, and not having any categories makes life so much easier (facepalm, sarcasm). But yeah, our branding doesn't look so nice when the user eventually resizes the Self Service window and the image gets stretched out of it's 2.98:1 aspect ratio... Yuck!
Posted on 02-23-2021 01:16 PM
I turned off the branding header image. The stretching makes no sense, when it shouldn't be difficult to just clip the image based on the window size.
Posted on 02-23-2021 01:29 PM
https://www.jamf.com/jamf-nation/feature-requests/10177/revert-self-service-s-design-to-the-10-26-version
Please vote!
Posted on 03-05-2021 01:58 PM
Its "stretching" because its not responsive to image size. This should be a easy bug to fix.
Posted on 04-12-2021 03:46 AM
If Jamf could change to scale the branding header proportional instead of streching or compressing it's width, it would be okay for me.
Posted on 04-29-2021 12:46 AM
Having the same problems with the macOS Self Service Store banner, too.
Posted on 05-24-2021 11:13 AM
I think I have figured out the problem. I think whoever put the specs into the template for the default macOS branding header may have made a typo.
The specs given are 335x1000
I went forward assuming that it was 2, not a 1.
My specs are now 335 x 2000
This shows my photoshop document in the background and my Self Service in the foreground, so you can see that the distortion is gone.
So I say "TYPO - It should be 2000 pixels wide, not 1000"
Posted on 05-25-2021 01:07 AM
@drioux I tried the 335 x 2000, and if Self Service is opened, and in its default size, it seems fine. However, once someone puts it in full screen or starts resizing it, it scales horribly.
Posted on 05-25-2021 08:53 AM
Interesting, it does scale horribly. It seems tied to the dimension instead of being free floating or scaling properly
Posted on 05-25-2021 09:53 AM
I do have a case open on this issue, and have given them this additional info. They have confirmed they are seeing the same thing, and the sizes appear to work also.
...getting closer
10-20-2021 06:57 AM - edited 10-20-2021 06:59 AM
Curious if this is still an issue with 10.33? There's a "branding" fix listed, though it mentions "icon".
https://docs.jamf.com/10.33.0/jamf-pro/release-notes/Resolved_Issues.html
10-20-2021 03:19 PM - edited 10-20-2021 03:22 PM
We updated from 10.26.2 to 10.29.2 to 10.32.2 yesterday.
I saved a Full Summary before the update, and after the first update, and after the second update.
These lines disappeared after the first update:
Do we get a t-shirt? 🙂
Posted on 10-21-2021 01:56 PM
Today we discovered the Branding Header shows only if you have Home selected.
Posted on 10-22-2021 06:52 AM
Yup. And now it is actually distorted right out of the gate, but now the art can get clipped as well!
Posted on 10-26-2021 08:34 AM
The pixel dimension probably changed.
