2016-2017 battery recall detection
swapple
Contributor III
Can Jamf detect MacbookPros with the battery recall issue so we can address the issue?? https://support.apple.com/en-us/HT212163
3 REPLIES 3
Dylan_YYC
Contributor III
Yeah for sure. First i would get the extension attribute "battery health status" found in the templates of the JSS, then once thats had a chance to run, you can do a smart group or an advanced search looking for devices with "service battery" listed and the model numbers of the affected devices.
gabester
Contributor III
I need to look at implementing this, I'm sure we have a few that fall into this warranty recall.
david_stahl
New Contributor
@swhps See over here for more chatter on this. Some scripts are also there for this
https://macadmins.slack.com/archives/C04QVP86E/p1612976303347700
