Posted on
02-21-2017
07:41 AM
- last edited
Tuesday
by
kh-richa_mig
When two-factor authentication is enabled, are multi-use QuickAdd packages still able to authenticate and enroll a device?
Solved! Go to Solution.
Posted on 02-21-2017 07:48 AM
They should be yes as a quick add doesn't exactly "authenticate" but rather uses an invitation id number to identify if the enrollment is authorized or not.
