$3 returning blank in scripts
McAdams
New Contributor III
I was having trouble getting a script to run dseditgroup using JSS 8.3.1.
dseditgroup -o checkmember -n /Default/Local -m $3 lpadmin
I kept getting errors about no group name being specified. I put
logger "the user is: $3"
which returned the user as being blank. Shouldn't the third parameter be
the currently logged in user? I worked around it by using a line found in
the archive
username=/usr/bin/w | grep console | awk '{print $1}'
Thanks,
-- jmca
4 REPLIES 4
bkvines
New Contributor III
John,
My experience with $3 is that it only works on scripts executed at login. If the user is already logged in, that variable isn't passed.
Bryan Vines
bkvines at wgclawfirm.com
tlarkin
Honored Contributor
This is correct, $3 only passes as the current user when the script is ran at log in.
sean
Valued Contributor
John,
http://jamfsoftware.com/kb/article.php?id=040
See the note section.
Sean
McAdams
New Contributor III
Thanks. Learn something new everyday.
