Posted on
12-07-2020
12:33 AM
- last edited on
03-04-2025
07:13 AM
by
kh-richa_mig
Hi, we have a pretty conservative configuration profile to only allow the user to launch apps from defined paths (for example "/Applications"). This works fine in macOS Catalina but now I have our first M1-Mac (wich comes with Big Sur) and it ignores that payload. I checked in system preferences under profiles that my profile is correctly installed and it is but I can easily download an app and launch it from my downloads-folder (wich should be blocked).
Posted on 12-15-2020 12:49 AM
Just updated my test-Mac to macOS 11.1 and still the payload does not take effect.
Nobody here using this?
Posted on 03-16-2021 11:24 AM
Having the same problem.
Posted on 03-17-2021 12:43 AM
Apple fixed this in macOS 11.2 (Build 20D64).
Posted on 03-17-2021 02:30 PM
Thanks, @matthias.bretz! Just upgraded to 11.2.3 and they're working for me again as well.
Posted on 07-19-2021 05:54 AM
I'm currently running 11.4 and I'm having the same issue the payload it's not loading Application restriction on the Big Sur. Any idea would be much appreciated
