Posted on
09-27-2017
10:07 AM
- last edited on
03-04-2025
02:42 AM
by
kh-richa_mig
I am attempting to restrict some iOS devices to certain apps, built-in, in-house LOB and App Store, all pushed from the JSS.
As expected, the rest of the apps disappear but one of the apps on the "allow" list also disappears. I know it's installed because I see it when I remove the restriction. This particular app is from the app store but I've seen this behavior with all types of apps. I've double-checked the identifier is correct in the restriction settings.
What am I doing wrong?
Posted on 10-02-2017 06:49 AM
Just to clarify, you're using the "Restrict App Usage (supervised only)" feature under Mobile Devices > Configuration Profiles > Restrictions > Applications right?
What App are we talking here?
