Auto fill Purchasing fields using info from DEP
  • December 9, 2015
  • 4 views
Is there any way to pull purchase information from DEP into the purchase information fields in the JSS? We use our oder numbers to add our stuff to DEP so purchase dates etc is already there it would be nice not to have to fill it out for each device then.
1 reply
Forum|alt.badge.img+15
  • December 9, 2015
I think I used to get a lot of this information from GSX. Of course, GSX is kinda difficult to integrate with the JSS these days, but if you can do it, you should get a bit of that info...
