Posted on
01-27-2017
11:59 AM
- last edited
Tuesday
by
kh-richa_mig
I am just wondering how everyone is managing automating Office 2016 updates with Jamf? I know that MAU 4.0 is supposed to have system level settings available but as of right now it is still user level. I have a very large number of dispersed lab computers that do not normally have admins login so I am wondering what would be the best way to go about forcing automatic download and installation of updates. I am sorry if this question has been asked and answered in the past. Thank you in advance for the advice.
Solved! Go to Solution.
Posted on 01-27-2017 12:57 PM
@ABigRock at the bottom of Rich's article you will find a .mobileconfig link that you can upload into Casper and use as a Configuration Profile. Set it to Install Automatically and at Computer Level.
Posted on 04-26-2017 05:04 AM
@rtrav I know the documentation states every 12 hours
MAU detects application updates every 12 hours...
but I left a test machine on and intentionally did not run updates but it did not install anything over night and it's been more than 12 hours.
Does anyone know a way to manipulate the time it takes to check in?
Posted on 05-23-2017 08:55 AM
neil.martin83 can you share - the profile that you used to auto download and install and lock out the MAU prefs?
Posted on 06-14-2017 10:43 AM
I've created a Configuration profile to push out that enables auto downloads in MAU and also registers each application as @neil.martin83 pointed out but it's not automatically updating the closed applications, only the open ones.
Should the configuration profile be user level ? at the moment i have it set to computer level.
(i did test at user level but it still didn't update the applications)
if i look at /Library/Managed Preferences/com.microsoft.autoupdate2.plist i can see the key entries,
when i look in ~/Library/Preferences/com.microsoft.autoupdate2.plist i do not (it's set to Auto Check and has no applications registered)
any pointers ?
here's the custom plist i'm sending in the configuration profile
<plist version="1.0">
<dict>
<key>Applications</key>
<dict>
<key>/Applications/Microsoft Excel.app</key>
<dict>
<key>Application ID</key>
<string>XCEL15</string>
<key>LCID</key>
<integer>1033</integer>
</dict>
<key>/Applications/Microsoft Lync.app</key>
<dict>
<string>UCCP14</string>
<key>LCID</key>
</dict>
<key>/Applications/Microsoft OneNote.app</key>
<dict>
<string>ONMC15</string>
<key>LCID</key>
</dict>
<key>/Applications/Microsoft Outlook.app</key>
<dict>
<string>OPIM15</string>
<key>LCID</key>
</dict>
<key>/Applications/Microsoft PowerPoint.app</key>
<dict>
<string>PPT315</string>
<key>LCID</key>
</dict>
<key>/Applications/Microsoft Word.app</key>
<dict>
<string>MSWD15</string>
<key>LCID</key>
</dict>
<key>/Applications/Skype for Business.app</key>
<dict>
<string>MSFB16</string>
<key>LCID</key>
</dict>
<key>/Library/Application Support/Microsoft/MAU2.0/Microsoft AutoUpdate.app</key>
<dict>
<string>MSau03</string>
<key>LCID</key>
</dict>
<key>/Library/Internet Plug-Ins/Silverlight.plugin</key>
<dict>
<string>SLVT</string>
<key>LCID</key>
</dict>
</dict>
<key>HowToCheck</key>
<string>AutomaticDownload</string>
<key>LastUpdate</key>
<string>2001-01-01T00:00:00Z</string>
</dict>
</plist>
Also, can someone point me to which folder the downloaded updates are stored in before they're installed ? maybe i can monitor that to see if it's working or not.
thanks!
Posted on 06-16-2017 10:30 AM
i've tested the configuration at user and computer level and looking at the /Library/Logs/Microsoft/autoupdate.log nothing updates when set to Download and Instal Automatically, i created a LaunchAgent and script to register the MAU app and Daemon once per user, is there anyway to confirm that it is registering them correctly ?
LoggedInUser=$( stat -f%Su /dev/console )
if [[ $LoggedInUser = "root" ]]; then
#create directory if it doesn't exist
if [ ! -d /Users/$LoggedInUser/Documents/.MAU_check ] ; then
mkdir /Users/$LoggedInUser/Documents/.MAU_check
done=$( cat /Users/$LoggedInUser/Documents/.MAU_check/MAU_register.txt )
if [[ "$done" == *"$LoggedInUser"* ]]; then
if [ -e "/Library/Application Support/Microsoft/MAU2.0/Microsoft AutoUpdate.app" ]
then
/System/Library/Frameworks/CoreServices.framework/Frameworks/LaunchServices.framework/Support/lsregister -R -f -trusted "/Library/Application Support/Microsoft/MAU2.0/Microsoft AutoUpdate.app"
echo "Autoupdate.app registered for $LoggedInUser" > /Users/$LoggedInUser/Documents/.MAU_check/MAU_register.txt
if [ -e "/Library/Application Support/Microsoft/MAU2.0/Microsoft AutoUpdate.app/Contents/MacOS/Microsoft AU Daemon.app" ]
then
/System/Library/Frameworks/CoreServices.framework/Frameworks/LaunchServices.framework/Support/lsregister -R -f -trusted "/Library/Application Support/Microsoft/MAU2.0/Microsoft AutoUpdate.app/Contents/MacOS/Microsoft AU Daemon.app"
echo "AU Daemon.app registered for $LoggedInUser" > /Users/$LoggedInUser/Documents/.MAU_check/MAU_register.txt
Posted on 06-20-2017 01:26 PM
Apologies for the late reply, life took over a bit...
@rtrav It checks at least every 12 hours and is invoked when you launch one of the apps. I need to double check the docs but I believe it'll run again after 12 hours if there's a registered app running (e.g. user leaves Word open for that long). It will only check for updates against apps that are registered with it (those <Applications> keys in its preference domain). If you're not managing those keys in a profile or by defaults writing them, registering the apps happens when each app is launched on a per app basis at the user level. If you have a user who never launches OneNote, for example, it won't ever update, unless you manage its <Application> keys.
@cbruce My profile is here, for reference: https://gist.github.com/neilmartin83/cb7ebe5f9afb3aa40e6d97d5bc917ded
Note that I am also managing preferences for our own caching server which holds both the collateral and packages. I also disable the Insider checkbox. I install this profile at system level and the closed apps also update just fine across my fleet.
As a side note, I have another profile which is the same as above, but points to a different set of URLs (subdirectories on my caching server) where I host the current set of updates - this lets me roll those out to a pilot group of machines for testing.
@May Here's the script I use to register MAU with LaunchServices so you don't get the nag dialog. I run it at every login via the JSS - it's not resource intensive and this method means it catches everyone. I noticed that after a MAU update, it needed re-registering, so that's why I did this, otherwise I'd have done it once per user. This method also means the JSS collects the output and logs it. You can get verbose output by adding the -v flag to the lsregister commands: https://gist.github.com/neilmartin83/4e704a0c627453ca216d413c2ae43182
This script runs as root (as it's being run by the jamf binary) so essentially works out who the logged in user is, then runs the commands to register MAU as them, plus deleting the <LastUpdate> preference key so that when they launch one of the Office apps, it'll check for updates right away. I'm lazy and didn't bother with the awesome amount of sanity checking you've put in yours because Office is deployed to our entire fleet. :)
Check /Library/Logs/Microsoft/autoupdate.log to see if it's doing what it should, it's pretty good at telling you that it's checking, downloading, then installing the packages. You can also enable even more verbose logging by managing the <ExtendedLogging> key (true/false).
All the reference material is here: https://macadmins.software/docs/MAU_38.pdf
Posted on 07-11-2017 07:28 AM
Thanks @neil.martin83, you've been very helpful in laying out the hidden pieces of this puzzle!
Good to know that MAU needs re-registering each update, i'll test out your login policy/script approach so i can set it and forget it rather than messing with LaunchAgents each update.
Posted on 07-11-2017 08:00 AM
Are there any particular tricks to getting login policies to run ?
I just created a policy with the Trigger = login, Frequency = ongoing, Make available offline is checked.
Double checked that Management Settings > Check - In > Login/Logout Hooks has Create login/logout hooks checked.
I've logged the user out and in a few times and also ran recon incase that's needed to pull down the script initially but if i check the policy logs it's still shown as pending.
Should i see something from the Policy within /Library/Application Support/JAMF/ManagementFrameworkScripts/loginhook.sh ?
(i can see that com.apple.loginwindow has this set as the LoginHook),
and will login hooks only run if the Mac is on the network ? (i was assuming that the Make available offline option would mean network wasn't required)
JSS 9.96
OS X 10.11.6
Posted on 07-11-2017 01:02 PM
I'm glad to say i couldn't get a login policy to run as it sent me down a different route, ideally i didn't want to wait for a user to login for MAU to get registered, i was looking at using /bin/launchctl asuser but couldn't get it to work then stumbled across this post which has a wonderfully simple approach to running commands under the user context, thank you @mm2270 !!
Now i can run this to register MAU once per user and each time there's an MAU update, hoorah.
LoggedInUser=$(stat -f%Su /dev/console)
LoggedInUID=$(id -u "$LoggedInUser")
if [[ "$LoggedInUser" != "root" ]] || [[ "$LoggedInUID" -ne 0 ]]; then
cat << EOF > /private/tmp/MAU_register_script.sh
/System/Library/Frameworks/CoreServices.framework/Frameworks/LaunchServices.framework/Support/lsregister -R -f -trusted -v "/Library/Application Support/Microsoft/MAU2.0/Microsoft AutoUpdate.app"
/System/Library/Frameworks/CoreServices.framework/Frameworks/LaunchServices.framework/Support/lsregister -R -f -trusted -v "/Library/Application Support/Microsoft/MAU2.0/Microsoft AutoUpdate.app/Contents/MacOS/Microsoft AU Daemon.app"
mkdir /Users/$LoggedInUser/Documents/.MAU_check/
EOF
echo "No user logged in. Can't run as user, so exiting"
if [ -e /private/tmp/MAU_register_script.sh ]; then
/bin/chmod +x /private/tmp/MAU_register_script.sh
/bin/launchctl asuser "$LoggedInUID" sudo -iu "$LoggedInUser" "/private/tmp/MAU_register_script.sh"
sleep 2
echo "Cleaning up..."
/bin/rm -f "/private/tmp/MAU_register_script.sh"
echo "Oops! Couldn't find the script to run. Something went wrong!"
exit 1
fi```
Posted on 08-01-2017 09:29 AM
All we'd like to do is just shoot a simple bash script using a policy in the JSS to our logged in users with the following:
defaults write com.microsoft.autoupdate2 HowToCheck AutomaticDownload
but for some reason, it's not working. If i copy and paste this into Terminal directly under the logged in user, it works.
Any ideas why?
Posted on 08-01-2017 09:34 AM
@monaronyc You have to write to the logged in user's prefs:
# Set Microsoft updater to automatically install updates from a local cache - requires changing the user's prefs rather than the global prefs in /Library/Preferences
/usr/bin/defaults write /Users/$loggedInUser/Library/Preferences/com.microsoft.autoupdate2 HowToCheck AutomaticDownload
Posted on 08-01-2017 09:47 AM
@StoneMagnet SWEET MARY JESUS! That worked! THANK YOU! THANK YOU! As you can see i'm still a bit of a novice with this stuff, but getting better thanks to folks like you and the JAMF community! One thing though, we're still not seeing that global prefs file in /Library/Preferences yet. Are we supposed to place that manually some way?
Posted on 08-01-2017 09:53 AM
@monaronyc As near as I can tell any com.microsoft.autoupdate2 prefs file in /Library/Preferences is ignored, and only the one in ~/Library/Preferences matters
Posted on 06-11-2018 09:12 AM
MAU 4.0 was released.
https://www.jamf.com/jamf-nation/third-party-products/384/microsoft-autoupdate?view=info
Posted on 06-18-2018 07:40 PM
Has anyone disabled the automatic functions and set it to manual? If so, care to share?
Posted on 06-19-2018 06:19 AM
@rkovelman Check out (https://github.com/pbowden-msft/msupdatehelper) for @pbowden's Jamf Pro helper script for controlling Office and Skype updates. There's a link on that page for a video tutorial on msupdate which shows how to disable the automatic updates by deploying a configuration profile.
Posted on 01-08-2019 02:00 PM
Juser wondering - are all admins always downloaded the latest office version ?. For years we have always been running 1-2 versions behind and updating 3-4 times a year, but never to the newest, as there always is a risk that the newest tuff is buggy and not fully tested ?` - but maybe this is not the way to think?
Posted on 01-09-2019 04:54 AM
I update mine about once a month and I use the auto update script from mac.admins site.
Posted on 01-09-2019 10:17 AM
@kericson Thanks for input. So you are using the msupdate script to update ? -
Posted on 01-09-2019 10:30 AM
Yes the one from Mac.admins site.
Posted on 01-09-2019 06:40 PM
@jameson , biggest issue with not updating monthly is that for the Mac version of Office, Microsoft doesn't have a separate channel for security/critical updates. So each month's updates on the Office 365/2019 are feature, security, and critical patches all in the same update. For Office 2016, they are now security only.
I wish Microsoft would bring their Mac development cycle in sync with Windows, where there are semi-annual channels that are supported for 18 months with security updates, in addition to the monthly update channel. In fact, on Windows the default channel for Office 365 Pro Plus is semi-annual.
Personally, I run about 1 month behind what is current. Usually a show-stopping bug will get publicized during that time-frame.
Posted on 01-09-2019 10:20 PM
@taugust04 Thanks for the input. We are on office365 and did not know that that that microsoft did handle Mac this way. For windows I knew the way as been in contact with our Microsoft guys in Company, so actually did think more of a manual way of upgrading semi annual way. But if security updates also are part of it, it should be quite often. So think the way you do it with once a month and not right away push new out could be a way to go.
Posted on 12-27-2019 11:20 AM
If automatic download and install are checked in MAU. Will this eventually install? Or does the user have to click update?
Posted on 12-27-2019 04:11 PM
@PCSysops the user will still have to click install but you will get NC notifications to do so. It will auto download in the background and prep the app for updates though. So, it should only appear when the download is completed. Been using this method via Config Profile for the past year at my current job. The most difficult part is convincing people to 1) click the update button or 2) quit their apps so they will auto update next launch
Posted on 03-03-2020 06:43 AM
Hi All, Has anybody figured out a way to update the apps automatically even if an end users doesn't use them?
i have the configuration profile set up to download and install.
-Peter
Posted on 03-03-2020 06:52 AM
I found this, has anybody tried setting this key as well?
https://github.com/pbowden-msft/Payloads/blob/master/MAU_AppArray.plist
Application Key for the Configuration Profile
Register applications that MAU should update. If this is not managed MAU might have issues finding updates for applications that a user has never opened.
<dict>
<dict>
<dict>
<key>LCID</key>
</dict>
<dict>
<key>LCID</key>
<string>1033</string>
</dict>
<dict>
<key>LCID</key>
</dict>
<dict>
<key>LCID</key>
</dict>
<dict>
<key>LCID</key>
</dict>
<dict>
<key>LCID</key>
</dict>
<key>/Applications/Microsoft Remote Desktop.app</key>
<dict>
<string>MSRD10</string>
<key>LCID</key>
</dict>
<key>/Applications/Company Portal.app</key>
<dict>
<string>IMCP01</string>
<key>LCID</key>
</dict>
<dict>
<string>MSau04</string>
<key>LCID</key>
</dict>
</dict>
</dict>
</plist>
-Peter
