Posted on 01-11-2013 08:08 AM
Guys got a problem
Our testers didnt report that with CS5 & CS6 installed all documents default to CS6
Trying a Getinfo and changing the open with all reverts back to CS6
Any one have a fix
i really need some help as i only want them to cs6 for internal work at the moment and cs5 for client work
Thanks
Posted on 01-12-2013 01:05 AM
I'd have duti script run @ login that sets the correct settings.
BUT, are you managing the launch service plist @ all.
Posted on 01-12-2013 10:06 AM
Take a look at http://www.rorohiko.com/wordpress/downloads/lightning-brain-soxy/
Does what it says (but it's commercial)
Ciao
Carlo
Posted on 02-11-2013 06:39 AM
You could also just push out a modified Bridge CS5.5 plist, i.e. com.adobe.bridge4.1.plist to ~/Library/Preferences with all the "file association types" (in Bridge preferences) set to open, by default, in CS5 and not CS6 applications. Bridge CS6, i.e. com.adobe.bridge5.plist automatically opens files in CS6 applications. So, in other words, with both versions of Bridge side-by-side you can avoid any compatibility issues that might arise.
