Posted on
11-06-2017
07:25 AM
- last edited on
03-04-2025
07:11 AM
by
kh-richa_mig
Trying to delete a local user from a machine remotely using Jamf remote. Set parameters to completely delete the user and home folder followed by an inventory update. The log shows the user and home folder have been deleted, but the computer and inventory still show user exists. Same results when including an auto or a manual restart of the computer. If I log out as another user and then in as the user account I was trying to delete it asks to continue setup of the account like it is the first time. Such as "Sign In with Your Apple ID". What am I missing?
Yes, I could just delete the user from machine manually, but what is the fun in that.
Solved! Go to Solution.
Posted on 11-09-2017 10:08 AM
Have you tried using sysadminctl
to delete the account? I'm not sure dscl . delete
is a good way to delete an account anymore under 10.13.
Syntax to use:
sudo sysadminctl -deleteUser <username>
Drop the sudo if it's run from a policy.
Posted on 11-06-2017 07:34 AM
Make that 10.3.1
Posted on 11-07-2017 06:45 AM
Unable to remove user manually either via system preferences or terminal.
I can see the user with dscl . list /users
but when using sudo dscl . delete /users/<userID> i get an access error
This is student machine that was set up to 13.1 for a new student. Joined JAMF using this account, then added student account and then wanted to go back and delete the original admin account that I joined with.
Not resolved, but changed the accounts password to a 'super secret' one that any kids don't know. Will test with another machine to see if it was machine specific.
Posted on 11-09-2017 07:25 AM
I was able to reproduce the issue on another machine. Is the user who joins JAMF pro with 10.13.1 not able to be deleted from the computer? Any response is appreciated.
Posted on 11-09-2017 09:58 AM
https://discussions.apple.com/thread/8087348?start=0&tstart=0
Posted on 11-09-2017 10:02 AM
http://www.hawkdive.com/2017/01/unable-to-delete-managed-user-account.html
Syntax to use:
Posted on 11-09-2017 12:08 PM
@mm2270 That did the trick! Many thanks!
Posted on 11-09-2017 12:28 PM
If Jamf Remote is still using dscl
and sysadminctl
is the preferred way now, that sounds worthy of a support case.
Posted on 11-09-2017 12:47 PM
It appears to only happen with machines that were moved from 12.6 to 13.0/13.1
A fresh install of 13.0 had no issue when added to MDM. I was able to remove an admin account by Jamf Remote, command line, terminal or policy.
Had some new students that came in and I gave machines that were upgraded vs machines that were erased and then with 13.0
