Deploy and Configure Enterprise Connect 2.0.6 on Big Sur 11.5.2
lehose
New Contributor II
Does anyone have any experience deploying/configuring Enterprise Connect to Big Sur using Jamf Pro?  Previous versions just worked by including the scripts that were created before my taking over of the task.  On Big Sur, the application installs without issues, but it does not configure the users file shares or password sync.  Anything to point me in the right direction would be appreciated.  Thanks!
5 REPLIES 5
georgecm12
Contributor III
I could be wrong, but I don't believe EC is supported under Big Sur. You should look to migrate to the Apple Kerberos Single Sign-on Extension.
lehose
New Contributor II
Thanks for the reply.  I had thought that 2.0.6 was going to be the last version compatible with Big Sur, but I could be wrong.  I'll look further into the Kerberos SSO option.
andrew_nicholas
Valued Contributor
Big Sur is the last supported OS for the app and it does seem to behave oddly, and my primary issues have been with it recognizing network status but configurations are otherwise working as expected. Are the configuration profiles for it deploying correctly?
I don't believe they are deploying correctly. After the actual install PKG runs, a post install pkg runs that contains the following script (I replaced the domain and server names)
ecUser=$1
notifyDays=14
#Create tmp files to write LDAP info to
userInfo=`mktemp /tmp/userInfo.XXXXXX`
domainInfo=`mktemp /tmp/domainInfo.XXXXXX`
#Pull the info with ldapsearch
ldapsearch -LLL -H ldap://states.mnstate.edu -b "cn=users,dc=domainname,dc=edu" -s sub "(sAMAccountName=$ecUser)" > "$userInfo"
ldapsearch -LLL -H ldap://ldap.server.edu -b "dc=domainname,dc=edu" -s sub "(distinguishedName=DC=mnstate,DC=edu)" > "$domainInfo"
#Set the variables time calculations. Outputs LDAP time
pwdLastSetLDAP=`cat "$userInfo" | grep "pwdLastSet" | awk '{print $2}'`
domainPwdPolicyLDAP=`cat "$domainInfo" | grep "maxPwdAge" | awk '{print $2}' | sed 's/-//'`
let domainPwdPolicyDays=$domainPwdPolicyLDAP/10000000/60/60/24
#Convert times and calculate how many days to expiry
let pwdLastSetEpoch=($pwdLastSetLDAP/10000000)-11644473600
currentTimeEpoch=`date +"%s"`
let pwdExpires=$pwdLastSetEpoch+$domainPwdPolicyLDAP
let diffDay=($currentTimeEpoch-$pwdLastSetEpoch)/86400
let daysToExpiry=$domainPwdPolicyDays-$diffDay
echo "Days to Expiry" $daysToExpiry
if [ $daysToExpiry -le $notifyDays ]; then
echo "reset password at site"
osascript <<-EOF
try
tell application "Finder"
activate
tell application "Finder" to display dialog "Your password is going to expire. Please change your password." buttons {"Change Password", "Cancel"} default button 1
set x to button returned of result
if x is "Change Password" then
tell application "Safari"
activate
tell application "Safari" to open location "https://starid.mnscu.edu"
end tell
end if
end tell
end try
EOF
echo "Won't notify user"
All this was created prior to me taking this over.  In the past I've just replaced the install pkg on the policy with the new version and things just worked.  As far as the jamf.log output is goes, it believes everything was successful
It doesn't look like any configuration profiles were created.  The PKG containing the configuration script completes without error in the jamf.log .  In the past I've just replaced the EC installer pkg on the policy with the latest package and left the configuration pkg alone.  That worked until Big Sur
